Thermionic Overunity Generator my gift to the world.
Started by Arthur1, March 31, 2015, 02:03:48 AM
profitis
Vladok:'Using Wolfram metall  (Electon capturer - high eV) coated with recomended Ag-O-C'
Ag-O-Cs has very low wf(around 0.1ev).it stretches into the room-temperature far-infrared. What happens to tungsten's wf if you put electric field of 2000v across plates.it plummets.big clues
pomodoro
Good article, shame about the very low current.
Imagine ionizing some rarefied gas and using the same principle to isolate fast from slow molecules with a magnet and an electric field.
Cold and hot electrodes as a result. Maxwels demon!
Vladokv
Low current, true. It will better serve as near 100% thermal converter in high temperature surroundings, like molten salt of thermal storage of thermo-solar powerplants. Number of thermal electrons rise considerably with higher temperature.
profitis
FETE.field enhanced thermionic emission.Schottky emission. Schottky effect:
In electron emission devices, especially electron
guns, the thermionic electron emitter will be biased
negative relative to its surroundings. This creates an
electric field of magnitude F at the emitter surface.
Without the field, the surface barrier seen by an
escaping Fermi-level electron has height W equal to
the local work-function. The electric field lowers the
surface barrier by an amount Δ W, and increases the
emission current. This is known as the Schottky
effect (named for Walter H. Schottky) or field
enhanced thermionic emission. It can be modeled
by a simple modification of the Richardson
equation, by replacing W by (W − ΔW).big clues
