Is Newton's Law At Risk?
Started by gravityblock, April 11, 2015, 09:50:41 PM
Is Newton's third law at risk?
Yes, there's a violation of Newton's law in this case!
No, Newton's law is in full effect in this case!
Not sure, I'm undecided ar the moment!
noonespecial
Quote from: Low-Q on April 14, 2015, 11:16:26 AM
I understand it completely. If you're right about the oscillation is the only reason why the CD-motor spins, you don't need a motor at all. You could just make a gear between the two purple flywheels and start spinning it by hand and released them. They would then power the CD-motor with its frictional loss forever.
Vidar
Apparently you don't understand. There already is a gear between the two purple flywheels.
gravityblock
We can replace the one way bearing with a scrollerwheel.  A scrollerwheel doesn't have the kinetic friction inherent in most mechanical bearings.  We can then convert the full reciprocating motion of the motionless axis by attaching a mechanical arm to it and the scollerwheel, or to one of the rollers inside the scrollerwheel.  This also eliminates the rope/chain and the friction associated with it.
References:
Scrollerwheel, http://en.m.wikipedia.org/wiki/Scrollerwheel
Scroller Mechanics, http://erikbrinkman.com/Scroller/Home.html
Gravock
gravityblock
Quote from: gravityblock on April 18, 2015, 12:57:29 AM
Gravock
According to Linevich's publication on page 4, Newton's third doesn't apply in this case (because: action is always equal to counteraction along one general straight line and is not distributed to a perpendicular direction).
Gravock
gravityblock
While we're at it, let's replace the two unbalanced purple gears with two unbalanced scrollerwheels to eliminate nearly all of the kinetic friction of the device.
Gravock
gravityblock
By using the scroller wheels, eliminating the rope/chain and nearly all of the kinetic friction in the device, along with converting all of the reciprocating motion to rotary motion, we may achieve higher efficiencies than the electronically controlled customized clutch used by Karanev!
Gravock
