Rosch taking orders on OU Bouyancy device.
Started by ramset, April 26, 2015, 09:52:03 AM
PIH123
Quote from: sterlinga on April 29, 2015, 10:26:35 PM
I bet you're in the bottom 5 percent in this crowd on that one.
But at least I have a lot of things to be happy about.
I am glad your wife left you.
I am glad that you have not "Supped" yet.
I am glad that you were kicked out your church.
I am glad you are living with your parents.
I am glad that you have major financial issues.
I am glad that not one person has stepped forward to support you in alphabetics. (is Andrew Bradley helping you out financially ?).
I am glad that almost no-one funded your recent "begging campaign"
I am glad that you support Stuart as your moderator (since he is helping bring down what is left of your business).
I am glad that you have been wrong about EVERY single scam you have promoted as real.
I am probably in the bottom 5 percent on all of that lot as well.
but wait ..................................
In the last two weeks only:
You have started posting material which on the surface, shows you are willing to question obvious scams.
You also seem to have dropped the workload on the supping quest and are not stalking Lindsey nearly as much.
None of you recent PESN energy postings contain alphabetics, where many previous ones did.
So maybe you are starting to care about your reputation ?
And I guess you don't like being goofed with on your youtube channel and at greaterthings ?
Not that you are seeking advice (you being god and all), but maybe you might want to strongly consider
taking a more balance approach on all of your online content.
I believe it will attract more people to your business and enable you start supporting your family
again without having to resort to "begging for groceries for Cherie" on your website.
allcanadian
@PIH123
I am glad your wife
left you.
I am glad that you
I
"begging campaign"
I am glad that you
That may be the most offensive post I have seen here at OU to date and your in the top 1% of the complete asshole department in my opinion.
AC
Quote from: hartiberlin on April 29, 2015, 08:32:56 PM
Newest findings:
Gaia admitted, that they use 2 IPCameras with Infrared Nightvison InfraredLEDs
with Power over Ethernet.
So there was no Emergency light from the hall, but this was the second IP Camera switching on its
Infrared LEDs and both cams were powered by Power over Ethernet cables
and IMHO probably the router was on an USV, so no power outage for the cams and router,
but the AuKW shut down, because the hall had a power outage..-> SCAM...
Also Gaia just posted 2 new videos themself here:
http://gaia-energy.org/liveticker-aukw-besichtigungen-30-04-2015/
Well, that explains why the image is in black&white after the light came back on, and accounts for the specular reflection on the heating panel that is in view. But if you look up at the top of the frame, it is pretty evident that there is some kind of lighting coming from up there, illuminating the top of the AuKW and casting shadows on the back wall that are not coming from the IR LEDs... I think.  I thought this was from the emergency light fixture, which typically has two spotlight-type bulbs in it pointing down and away at angles. Whatever is casting that light is out of the frame, but it certainly looks like there is light coming from up there.
MarkE
So, Pete, by your saying "your 911 ravings," I take it that can add you to the list of "show me the data" doofuses who believe the establishment line on 9/11. I bet you're in the bottom 5 percent in this crowd on that one. Pretty obvious. Come one. Can a building fall at free-fall speed without help from the inside? Any non-political physicist knows the answer to that one, easily.
I can't disclose details, but I assure you my conversations were extensive with LS. I'm not referring to the one post you're referring to.
Any physicist that isn't a few eggs short of a dozen will tell you that there is no such thing as "free-fall speed".  There is acceleration due to gravity.  And there is velocity dependent viscous friction with air that changes with atmospheric conditions.  For a given vertical drag coefficient a terminal velocity exists that is reached after falling for a sufficient time.  For skydivers jumping around 10,000' that's about five seconds and almost 1000' drop.
To find out what happened physically to buildings damaged and destroyed at the WTC on 9/11 you could always read the NIST report.  That report was written by knowledgeable people who evaluated the evidence in detail.  And contrary to your evil and unfounded accusations not one of those people is part of the heinous cover-up plot that you allege without a shred of evidence.  You accuse those people of being part of a plot to cover up the murder of thousands of their country mates.  Consider how you will explain the false witness you've born and continue to bear when you eventually face your creator.
MarkE
Quote from: sterlinga on April 29, 2015, 10:33:43 PM
To prove that you're "full of it" on the pathological skeptic end of the spectrum, let me cite AN example that obliterates what you just said.
SHT has had three third-party tests by highly reputable organizations doing quantitative analysis showing ~500x, ~1300x, and ~900x output. Four third-party tests showing ~97% H output, from H2O input.
Also, Rossi has had considerable testing done, not to mention that his technology was purchased by Industrial Heat, as part of a 2 billion dollar fund, if I remember right, after 1 year due diligence.
You're like the Wright Brothers skeptics who for four years continued to say heavier-than-air flight would not be possible, despite the FACT that they were flying around doing demonstrations. Now that is obvious, then it wasn't. Guess where I would have been back then... Versus you...
You have been taken in by SHT just as badly as you were taken in by Mylow.  The third party tests performed for SHT did not establish an input / output energy balance.  They did not establish their claim that they convert water to hydrogen gram for gram.  The test reports published reported on:  1) Electricity supply to the unit under test, 2) Gas outflow volume, and 3) Chemical analysis of the outflow.
What you seem to gloss over every time is that SHT's device uses a metal consummable that they admit is part of an oxidation reduction reaction evolving hydrogen.  That admission alone kills the gram for gram water to hydrogen claim, independent of the absurdity of the notion that they would transmute an oxygen atom consisting of 8 N, 8P, 8e to 16 hydrogen atoms of 1P + 1e each.  All fission for elements lighter than iron is energetically unfavorable.  That means that if SHT's claims were true, the energy value of hydrogen to oxidize  would be many orders of magnitude smaller than the nuclear energy imparted to fission the oxygen.  SHT's crack team would have you believe that they have a process that turns sand into small sapphires that just happens to make Hope sized diamonds as a side effect.
Rossi is yet another scam artist.  After more than four years of claims, and three years of supposedly delivering those trailer load MW power plants he still shivers each winter in his long coat and propane heated offices in Bologna.
