How Rosch probably faked their 5 KWatt KPP AuKW
Started by hartiberlin, May 05, 2015, 10:41:49 PM
NochWas
The host-presenter of the auKW on J.D.s  video seems to be somewhat stoned with psychopharmaka. His movements seem to be lame and hesitating indicating he uses heavy Dosis of medicaments against states of  overwhelming fear....
That is not a promising indicator for the credibility of the auKW....
hartiberlin
If they have done the fake still more right, then they would have a 3 phase frequency changer unit in the next room which
will be controlled wirelessly via the antenna there... This unit could then produce the right frequencies before the hidden cable goes up there,
so that you can see the same frequency on external frequency meters or scopes, at the measurement day today...
@NochWas,
Mr. Beiser is said to have some kind of Nerve-Illness. That is why he is a bit slow in speaking and answering.
I don´t know, if this is true, but that is a rumour.
hartiberlin
PoiPoi has found the right compresssor pump !
https://www.allmystery.de/themen/gw113123-1131#id14248581
Here is a page from the manufacturer.
It must be the model Airpump 150.
This one still works at a deepth of 5.5 Meters.
Too bad, I have not yet found a chart, which displays at which pressure
it will deliver how many liters of air...
http://evolutionaqua.com/acatalog/Airtech_Fittings.html
Here is a PDF File from the Service Manual !
http://www.evolutionaqua.com/acatalog/AirPump%20Manual.pdf
hartiberlin
If they really just use a variable frequency drive (frequency inverter-converter) in the next room controlled remotely via the antenna
then the speed change noise could also just come from the membrane pump , when they change the frequency in this variable frequency drive
and then the generator maybe is not at all
connected electrically and really runs only fully in idle mode.
so the small gear is always able to drive just the shaft of the generator as it does not have any counter torque, but just runs completely idle.
Regards, Stefan.
hartiberlin
In this new video I explain, how they could have done it to fake the whole setup:
https://www.youtube.com/watch?v=Cj9VuE-vNnw
