R-Walker Selfsustaining Free Energy bike from Mexico
Started by hartiberlin, May 11, 2015, 02:29:11 PM
FatBird
Can somebody Post a diagram of the Capacitor Circuit DON SMITH is describing in this Video.
https://www.youtube.com/watch?v=BJ8CHJscmR8&feature=youtu.be
lespaul109
FatBird
@  Lespaul109
Thank you for posting that.  Can you answer any of these?
1.  Does an antenna connect to the Capacitor Input?
2.  Have you had any results yet (good or bad)?
3.  Any helpful recommendations?
Thanks.
jimbo
Hi guys here's my take on don smith's work start with a hivoltage source neon transformer. Use diodes to make the energy pluse  for switching reasons . use a Hi freq for faster switching pluse switching on and off.the coils tuned to the switching frequency to bring the AC resistance to zero .like tuning a radio dial if you there you'll get your desired result .station.all so the coil magnifys the voltage greatly.. Massive potential difference is made there in DC pulsing voltage ...this is the main form of energy needed for attracting electrons....then more coils all tuned to that coil in resonance so there's no resistance at all each coil is earth grounded so they're pulling current out of the ground with every positive pluse.now put a Hi voltage diode string in that ground line ...one way switch... And expose it to the caps for charging....like don said the more caps the more power...as you bleed off energy from the system it is replenished Thu the ground and when your not using it it fills up the caps and reaching its max potential stops till used again.he's using magnetic inductance Thu tuned coils for replication of power each getting hi fast POS pluse energy each regauging pulling electrons out of the earth like crazy trying to keep up with the conditions. There by making many copy's of the original powerful imbalance of positive energy. Free energy  .I just use... no coils ...no tuning just pure simple electrostatic induction .same principal just simple enough to charge a battery. And the voltage is not as dangerous.  Jim out . if you can understand this you can understand all of them..👍
Turbo
the energy has to be switched fast.
this is done by digital multiplexing very similar to a SDR or software defined radio.
