Extracting energy from A-Vector potential
Started by Magnethos, June 16, 2015, 02:52:50 PM
Magnethos
Hi again,
After watching an old video from ingener99, I've came with an idea. The idea is a possible answer about the closed loop wire around the microwave oven transformer and the doubt about extracting energy from it. How we can extract energy from a closed loop wire that only contains amperage?
Well, look at the picture to see what I mean.
Basically the idea is to use a Rogowski coil to extract useful energy from the closed loop, instead of using an ordinary coil winding around the core of the closed wire loop.
http://www.electronicproducts.com/images2/fapo_TI_SmartGrid03_jul2011.gif
ATOM1
The ambient ????? Do you mean the natural harmonic of the mass ??? A high state of frequency as a dielectric constant which jumps down to a lower frequency to produce photons ????? It would be a 5th note along the harmonic scale ! On a piano you hold down the 5th note of the scale and play the first note of the scale and the 5th note will vibrate without playing it .........................................
Have you tried this ambient and did the light switch on ???????????????????????
ATOM1
Dave45
Quote from: Magnethos on June 17, 2015, 06:00:10 PM
Hi again,
Another way is to run the large shorted wire through a wire wound toroid and pull energy that way.
Mr. Moroz made use of this configuration.
https://www.youtube.com/watch?v=dFGTQ06yeEw
Magnethos
Quote from: Dave45 on June 17, 2015, 09:34:58 PM
As I see Igor is also using Rogowsky coils and Bucking coils.
I noticed that a Rogowski coil can be used in 2 ways:
1 - Wired around the toroid
2- Wired in a specific point of the toroid like ingener99
The key part is to know if in the tests I suggest the output affects the input (reflectance). It's the main question to answer.
Thanks for the video!!
Magnethos
Here you've the two ways of winding a rogowski coil-like wire in a closed loop (toroid core, closed loop wire...).
