Extracting energy from A-Vector potential
Started by Magnethos, June 16, 2015, 02:52:50 PM
synchro1
Quote from: Magnethos on June 18, 2015, 08:30:14 AM
Here you've the two ways of winding a rogowski coil-like wire in a closed loop (toroid core, closed loop wire...).
The "Siamese" toroids of the Quadra "A" vector project producing an anti gravity effect below: The coils move upwards when charged.
Magnethos
Quote from: synchro1 on June 18, 2015, 06:19:18 PM
Where can I find more information about that subject?
I've been searching on Google about "siamese toroids" and I've only seen 2 results. Can you say me where have you got that picture?
EDIT: I've found the info. Thanks anyway.
Magnethos
That experiment is similar to Boyd Bushman coil. Bushman said one time that it was based on a 'second generation' Lenz Law.
https://www.youtube.com/watch?v=mP5JgG1-0jg
sm0ky2
V(t) = L dI/dt
Where:
t = time
V = Voltage
I = Amps (current)
L = Inductance (Henry's)
On one side of the transformer, you have a low voltage, higher current
on the other side you have a low current, higher voltage
Power through the transformer remains the same, over time.
If you pull current from the closed loop, you change the Inductance.
sm0ky2
That is not "anti-gravity", it is electromagnetic repulsion.
like the mag-lev trains
Its' no different than placing two magnets together in repulsion.
if an A/C signal is used, you can control the amplitude of the repulsive effect by bringing the two signals into and out of phase with each other.
Or varying the frequenies between harmonic and disruptive combinations.
