Reflectance-blocking circuits
Started by Magnethos, June 18, 2015, 10:34:53 AM
Red_Sunset
Quote from: Magnethos on June 18, 2015, 10:34:53 AM
I open this thread to share ideas and investigate about reflectance-blocking circuits.
Hi Magnethos,
I think you have started a worthwhile topic that addresses the core issue that is central to energy conversion systems.   Let me write a short contribution in the limited time I have now, I can expand more on a later time.
I think Heins Thane made a great attempt in trying to neutralize the feedback mechanism but it also highlites the multi dimensional aspects difficulties of a mechanism like that.  It is worthwhile to understand these different aspects clearly, before attempting the next generation "Heins Thanes"  transformer
In electromagnetics, the mutual inductance (reflectance) as an extension of self inductance is the mechanism that regulates the energy flow.  Electromagnetic energy generation is based on field destruction or motion neutralization, or a combination of both.   The actions to break/neutralize any of these flows of symmetry requires energy input, a type of catch 22.  The magic to find is a process that requires less or is inherent in the make-up of the device.
In this pursuit I see the following focus points that needs a solution (possibly more items can be added, some solutions are already seen)
1..  Blocking the BMMF in the path of the FMMF
2..  Neutralizing the secondary MMF  (to neutralize selfinduction)
3..  Space separation  (these processes take place in the same place at the same time)
4..  Minimal energy input for any of the above actions
What makes interesting study is the similarity & difference  between a solid state (transformer)  vs. mechanical motion (generator) power generation process.
Red-Sunset
Magnethos
Quote from: Red_Sunset on June 19, 2015, 01:50:18 AM
Hi Magnethos,
Red-Sunset
Hi Red-Sunset,
I'm asking to myself this question for some time. In the net anyone can find some information that tells that is possible to extract real energy from the reactive energy. I mean, to feed the system with reactive energy without modifying the power factor of the power source when the load is connected in the output. In conventional circuits when you connect the load in the output, the power factor of the input changes. So in conventional circuits there is a 'communication' between the output and the input and this communication is bidirectional (input to output  ;  output to input). This communication is based on magnetomotive forces.
Anyone knows that reactive power can be extracted from a power source and that energy is wattless. Extracting real energy (watt energy) from the source is the main cause of power source depletion (in the case of a battery), but the most important key is that it seems that is possible to extract reactive power from the power source and this energy can be transformed to real power without affecting the power source. It will be a kind of 'unidirectional transformer'. This unidirectional transformer would be a transformer that is feed with reactive power in the input and consumes real power at the output. It seems that as long as you don't extract real energy from the power source, the power source can bring big amounts of reactive power to the circuit. Some people will say that it's possible to bring 'infinite' amounts of reactive power, but I don't think so. The thing I think is that there is a small advantage of feeding the system with reactive power compared with real power. Of course, the output needs to use real power to perform work. And this real power seems that is possible to obtain from reactive power without affecting the power source. Thane Heins is one person that shown some evidence about this, and there are other people that also explained similar phenomenons.
In the focus points you suggest, I think point #1 is quite important. The others are also important, but for some reason I will select the first point. In the mechanism I've explained, the theory is about blocking the BMMF to prevent that BMMF reaches the power source. BMMF would be generated, and it will be trapped in the receiver part of the circuit. As long as the BMMF doesn't communicate the power source, it can be generated BMMF. The key is to block the contact of the BMMF to the source of energy. Other people have suggested about the use of bucking coils to get a similar effect (maybe this will be more related with point 2).
QuoteWhat makes interesting study is the similarity & difference  between a solid state (transformer)  vs. mechanical motion (generator) power generation process.
A DVD I recommend is 'Electric motor secrets' of P.Lindemann. He explains about why the generator he explains is far more efficient than classical ones.
Also, some electrostatic generators I think they can be tagged into this category. When the load is connected in the output, no change is seen in the input. There is one motor called Kundel Motor, where it can be possible to see this effect. The output doesn't affects the input.
https://www.youtube.com/watch?v=wC50BPyx6AA
