Can anyone identify this 'Mystery Magnet Motor', or provide any information ?
Started by guest1289, July 03, 2015, 06:03:39 PM
guest1289
   Can anyone identify this  'Mystery Magnet Motor',  or provide any information about it   ?
   This  'Magnet Motor'  did appear on Google-Image-Search  3 or 4 months ago,  but now no longer appears anywhere on the internet.
_________________
  NOTE :  The reason why it should work  -  Magnets always move to the middle point of a magnet (
    and I assume that magnets always move to the middle point of a piece of metal ).
      So,  all of the magnets behind the last magnet on the wheel to leave the component on the diagram labelled as  'A' ,  will have a  'total magnetic force'  which is greater than that of the last magnet on the wheel to leave the component on the diagram labelled as  'A' ,  which would result in rotation.
_________________
    (  The longer the component on the diagram labelled as  'A' is,  the greater the effect  )
    The diagram shows the direction of rotation
guest1289
    Thanks for solving this one
    (  I cannot build anything,  and certainly not in a symmetrical and accurate manner )
    Its good to know it wouldn't work (  it was bothering me that it might work,  thats why I've posted it about 3 times  )
     P.S  The only other idea I had for a  'Magnet Motor'  that might work,   would be to exploit a very-slight delayed reaction in some diamagnetic material such as bizmuth( bismuth ),  so that when the Shielded-Magnets on a wheel ( shielded to produce a very small FAR-AWAY window( or angle ) for interaction ) approach the bizmuth,  there would be no-sticky point,   I could imagine that this particular effect would only work  above  a certain very high RPM
guest1289
I FOUND A WAY TO ELIMINATE ANY MAGNETS INTERFERING WITH EACH OTHER ON THIS PARTICULAR  'MAGNET MOTOR'
(  For those worried about interference between magnets  )
The wheel should be shaped like a  DRUM,   and the surface of the drum should be divided into  'tracks'.
  -  Into each track,  put a magnet (  in such a way,  so that it will look the same as  'THE SIDE VIEWS I POSTED IN THE FIRST POST'  ).
     NOW FOR THE IMPORTANT PART,   FOR EACH TRACK,  INSTALL A SEPARATE  COMPONENT 'A'( it's labelled on the diagram in the first post ) .
        -  Also,  put shielding between each  COMPONENT 'A'( it's labelled on the diagram in the first post ).
     -   And also important,  either use much fewer magnets on the wheel,  so they won't interfere with each other,  or,   put shielding between the magnets on the wheel.
       -   THE EASIEST OPTION HOWEVER,   WOULD BE TO MAKE THIS  DRUM SO WIDE,   THAT NOTHING WOULD INTERFERE  WITH  ANYTHING  ELSE (  no shielding needed ).
      (  If this  motor  really would work,   post a video ( even anonymously ) to show it.   Free-Energy suppression doesn't exist,    because no device has ever worked,  there's been nothing to  suppress   )
ATOM1
PLEASE STICK TO THE DRAWING POSTED ! Yes there many ways to do it  but this way is interesting just needs some coils and caps ect .... Its got a flux buffer to it so each magnet is north than south and it will not cause any back emf problems ect. Should run very fast ! Does it have a patent on it ????
ATOM1
