Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
ramset
Sir Nix
Based on your Utube evidence of " _successful _ magnet motors ( your low power examples ?) "
Your input is much more than questionable !
any truly self running "magnet only motor " would
Be world changing , regardless it's usability!!
Magnets shown doing work ??
Perhaps you are not an open source fellow who shares his work ?
No doubt you do look to make trouble !
Edit for comment below
Sorry to read that ....if you were not so condescending and arrogant, I would ask
You to prove that claim !
But since you do not open source your work
And proportionately your interactions are mostly
Combative?
Your more a fire starter than a true helper !!
Thanks Grandma
nix85
I am not trouble, i just may have little patience for time wasters.
As for the videos...
(i removed the first one to leave just the magnet-only ones)
Take the first one, my favorite, at any moment circa 6 magnets want to go (up the slope) and 1 or 2 wanna stick. Since base is probably iron too, overall effect is continuous motion.
https://www.youtube.com/watch?v=Me0s25_Xbnc
https://www.youtube.com/watch?v=vkcFRLQiVGk
https://www.youtube.com/watch?v=K73R6dMJRCI
https://www.youtube.com/watch?v=pYLF9UJDbkU
https://www.youtube.com/watch?v=PIvZJ9xGutI
You may not believe in these, but i believe all these are real.
nix85
"condescending and arrogant"
Ok, think what you like. Like i said, i may be bit impatient with people when they appear to waste my time, that's all.
nix85
"Your more a fire starter than a true helper !!"
Not to mention the ungratefulness.
I proposed a theory that is clear and makes sense, unlike some others here.
I posed some key questions, is rotor even a magnet or not, if yes, is it polarized along the long axis... The guy you presumably think was a true helper on the other hand gave theory which is totally unclear and contradictory, did not posit these key questions.....when i approach any issue i go to the root of roots, absolute thoroughness is the ONLY way, be it mechanical or solid state approach.
Shared number of videos of related devices that work.
...Nevermind
Semi
Hey Guys,
thank you for taking the findings we've found and published to account.
With we, I mean Ufo and me.
We are almost having to remind our selves all the time, that we are again trying to display our assumptions as facts we think we know.
We are even trying to consider the possibility of optical illusions or rather effects that can take place from or within the footage. Like the wagon wheel effect.
And backed up with some sort of Benchmark of Details we can find, the level of "most likely" arises.
I really would like to have this kind of discussion about details from the Footage, within the Secrets of Lüling thread. Then can I update and add details
to that page and it will grow over time.
The question If Mr. Lüling was using Magnets on or within its Armature, definitely has its place to be asked. We did the same, many times, but so far I can't
find any evidence that backs this up. So for now, I would say No. Neither the shown motion nor the mechanical details we can see, shows any sign of a Magnet
that rotates with the Armature. If someone finds anything that proves me wrong, I am happy to update those findings.
Regarding the way of Neutralization, I like to call it that we are lost in definitions. For my understandings, Ufos definition describes it as extrinsic, while
Mr. Lüling describes it as intrinsic.
And btw: Mr. Lüling never claimed that he has built an OU device. Only that its rotation is caused by Magnets, instead of Gasoline ignition.
@Ufo,
I am thinking of this for quite some time...
Compared to an ICE, like in a car, If I shift the first gear, and the rpm goes down, I put the pedal down, and the rpm goes up.
If I maintain this, it will keep my speed and rpm up. This is more or less done by changing the amount of Gas and Oxygen that ignites.
How do you maintain the speed, or rather the rpm? How do you change the amount of Gas and Oxygen? And what is your Gas and Oxygen?
What happens with your motion if you leave the outer repulsion side out? I've noticed on a test rig, the way how you pull the attraction side away,
will give the rotor a different push.
Semi
