Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
dom444
I am currently waiting on some magnets but have already worked out a better system where by you move the magnets with a cam same as a car valve and not the iron blocks, should allow faster revolutions as less weight to move which probably the biggest problem with his system.
anyone on this forum thinking of patenting should watch this.
https://www.youtube.com/watch?v=w7QauYjhuZg
dom444
A little hint to anyone out there trying to replicate this and this is very important
make sure that if you are mounting the plates on the horizontal plane  or vertical it must be that  the bearings must be firm with no play and also the magnets, or you will not achieve proper rotation of the disc or the rotor the
rotary motion comes about because of the initial attraction of the magnet and because it has no where to go it translates into rotation and this  will be dissipated if there is any wobble in the assembly,  i have already found this out.
http://panacea-bocaf.org/patentoffice.htm
Thaelin
   On the cam and lifters, sometimes the simplest way is the best way. The only reason to complicate things is to hide things. Way too many examples of that the way it is.  In short, KISS
  thay
dom444
that is true Thaelin funny thing is friedrich luling didn't really hide anything, they are showing you the internal works of  the unit, it is just moving to fast, but with our computers it is easy to slow it down now and follow what is going on and he even tells you.
In Stefans translation he says it attracts the rotor to the sticking point and he has found a way to neutralize the magnetic field to allow it to continue on.  1957 was a time when people had integrity many of the old inventions on film showed it all,  it was not about patenting and becoming a millionaire,  money is the driving force now.
I also think at that stage of technology they didn't have the pool of knowledge we have now and that may have been the only way he could come up with if he had magnetic modelling he would also had done it different.
and another hint for people trying to replicate the rotor must be balanced you have 2 steel or iron plates on both sides of a rotor, you need to counter weight it at 90 deg to the plates so you have a balanced spin.
Eniac5state
Can we first keep it simple ??  This is how a magnet motor should work:
Make magnets on rotor. Say two or four.
Now get a stator magnet in the vincinity of the rotor magnet.
The rotor will now turn towards the stator. Easy. But now the rotor will stop at that point so,
the stator magnet should isolated so the rotor can run in its own momentum. Easy.
But a trick, what if we use a high efficiënt elektromagnet as the stator magnet?
We don't have to shield anymore and can use neodymium magnets !
"But a strong elektromagnet costs energy" say the dummies. Not anymore. There is an
elektromagnet that can hold a person with two AA BATTERIES ! They are on sale.
Just make those switchable and the engine is nearly ready. Smile and start building.
Then attach a generator to it.
