Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
Quote from: Low-Q on December 23, 2018, 10:31:15 AM
Ok. I'll let admin know you're littering the forum, or did your computer post the same text over and over?
What I can write here is : I DID NOT WRITE THIS " blue #79" PHRASES !
Anybody is playing here around and yes the Admin should look after this poster #79 at 01:33:12 P.M.,cause the post #78 from me written has the same timing,01:33:12 P.M. !
2 posts in same second : impossible -physically and technically from my side ! BTW : working from a Tab
Sincerely
OCWL
Ufopolitics
Hello to all,
I am new to this Forum, even though I have been researching and developing F.E for a while by now.
I have debunked and built a learning model to understand how Luling Motor really works...
1-First, Luling found a way to "Neutralize" Magnetic FORCES, NOT the Magnetic Field...and that is based on an old concept of vectoring forces of opposite directions always cancel to zero.
On this event we will have to separate the two main parts on his motor (rotor-stator) to then apply the zeroing opposite formula.
Magnetic forces are very linearly propagated, based on a bisector, a dividing line that divides magnet in exactly two equal sides, perpendicular to the bloch wall.
So, our magnets must be perfectly aligned by this bisector, all, stator and rotor at a certain momentum of rotation.
Here are some images to understand what I explained before...
https://imagizer.imageshack.com/img922/9159/aS6rIm.jpg
https://imagizer.imageshack.com/img922/2976/HEbStE.jpg
Once We achieve a perfect* Neutralization, we could spin our rotor with very little to zero feeling of cogging (repulse) or sticking (attract) ... just like Luling moves with one finger his huge rotor...no stopping, not hard to pass angles...
*A "Perfect Neutralization" is NOT going to be achieved easy,...the setup can NOT be flimsy, with misalignments, have shaft-rotor play, or loose magnets...and there must be a side (either attract or repulse) where we could be able to manually adjust (screw) air gap back and forth to the half millimeter precision...until we feel it is smoothly neutralized.
2-Second, Luling uses Compressed Air (Pneumatics) in order to "brake" this neutralization point before the sticking point, or before the repulse force stops rotor.
The "lines" observed on his only video, are not electrical, nor solenoids or electromagnets of any kind...they are air lines!!
For those who know about Pneumatics, knows that a Linear Actuator is the square box with two lines into it...a linear actuator cylinder piston that pivots the reciprocating bracket attached to a shaft in charge to transfer, back forth movements to the other three "modules...
Observe the picture below from his video...
https://imagizer.imageshack.com/img924/8442/OavrFy.png
Then analyze what I wrote...with the help of the circled, checked parts, on img below:
https://imagizer.imageshack.com/img922/6887/MM5dcb.jpg
Thanks for reading me...and I will be back...
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Hello to Everyone,
Well, they always say that "Extraordinary Claims" require "Extraordinary Proof"...and that is exactly what I will do by just uploading below my Video as a Solid, Undeniable Proof... 8)
https://www.youtube.com/watch?v=ytCVQ-OZZmM
Thanks and Regards to All
Ufopolitics
―Leonardo da Vinci
ramset
Sir
It is wonderful to have/read such a diligent experimenter as yourself,
And more wonderful you share your work !
You do amazing work !
With respect and gratitude , and hoping for a better world!!
Respectfully
Chet K
Ps
There are many amazing open source  builders in these forums
And many more learning and watching and experimenting !
EDIT for comment below
I did send you a pm on builders boards here ( Stefan has made areas so it's easier for presentation
And managing!
Regardless your choice
Thanks for sharing!!
Thanks Grandma
Ufopolitics
Quote from: ramset on July 04, 2021, 02:30:47 PM
Sir
Respectfully
Chet K
Ps
Hello Ramset!!
Yes friend, and I highly enjoy so much sharing!!
And this is just the Tip of an Iceberg my friend...and just the "smallest tip" merging from an Ocean of horizons...its huge underneath!!
I will be sharing all components used on this very simple setup...just because they are still utilized in the Automation Industry...and very cheap, plus what a variety to choose from!!
Regards and Happy Four of July!!
Ufopolitics
―Leonardo da Vinci
