Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
citfta
Hello Ufo,
Welcome to a real forum for overunity projects.  Thanks for sharing your work.  Impressive build and clear presentation.  I am looking forward to your future videos and info.
Take care,
Carroll
Ufopolitics
Quote from: citfta on July 04, 2021, 04:01:29 PM
Hello Ufo,
Take care,
Carroll
Thanks Citfta,
I mainly wanted to share on this Thread about  Luling, my findings, since I have seen on YouTube, the efforts Stefan has been doing to find a Patent or any clues that will  lead to a successful build.
I appreciate your nice comments about this video, basically coming from you, being so strictly guided by Science...
And so, I would like to know your personal opinion after seen my video, about Science telling Us that "Magnets have no Energy"...
Or that Magnets possess some kind of "Conservative Energy"...which will not allow them to do any work...
Concluding that Magnets in Stator and Rotor of a Motor will never work...
And yes, I understand I am using an External Power (Air), which is similar to the ICE using Electricity to run...but the power is in the Gas Explosion...right?
Nice to see you around here Carroll!
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
citfta
Hi again,
I most certainly DO believe it might be possible to harness the energy of magnets.  I don't have time right now to look up and share the videos I have shown on this forum of my many efforts to understand and harness the energy of magnets.  If you look in the builders section of this forum under "Floor's" area you can find my videos of possible motor magnet ideas as well as videos of my testing of the forces of magnets.
Take care,
Carroll
dom444
It has Been a few years since i did work on this this but  it came to mind again the other day, i had a bit of a brain wave a very simple way to break the magnetic lock [size=78%].[/size]
[size=78%]
[/size]
two small  steel plates mounted on non magnetic material connected to the rotor each side of the magnet at the locking point as per my modeling the two plates will
attract the magnetic field to them and overcome  the lock because the steel blocks are cutting the field from the side they should not lock them selves
Ufopolitics
Quote from: dom444 on August 05, 2021, 11:55:04 PM
[size=78%]
[/size]
Hello dom444,
Sorry, but your idea will not work...and it is simple why...
Magnetic Fields can not be "cut" nor blocked...much less by steel plates...all you are  doing by adding steel plates is to "expand" the field, no matter where you set this plates...it do not work like that.
Have you tried to build this setup?
I do not think so...
You could use steel plates between poles to "shunt" the field...that means to weaken the field by using kind of a "short circuit"...and still, the field would still be there.
Ufopolitics
―Leonardo da Vinci
