Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
Ufopolitics
By the way...@All
Here is a MUCH BETTER High Definition Video of Lüling Motor.
In 4K UHD that I did directly from copies from the Original 35mm Celluloid Track.
Thanks to Member Semi, from Germany, who purchased these original frames from Bundesarchive.
It have Subtitles in German, English, Spanish, Portuguese...
Now You guys can see every single detail, bolts and nuts...pistons and actuators more clearly... ;D
Lüling 4K UHD from 35mm Original Film
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
knovos
Thank you very much Ufopolitics for taking the time to highlight the most important aspect of getting this engine to work. It was immediately clear to me in the video that it has to be a very fast sharp push back, that's why Luling opted for compressed air with which you can make such a fast sharp push back quite easily. In the example my push disk is just put down to show where I want to go, it is clear that it will not work there at that position. I will have to study what mechanical constructions there are for such a task. The great thing about this machine is that we don't have to gamble. It is very clear what needs to be done and how everything works. You made a cristal clear video and showed the world a device THAT WORKS! I'm going to move to the builder's forum you're suggesting, and go from there.
jimbo
I'm a little late but as a bit steel is becoming magnetic it flips its domains into Alinement until there all used up then what happens is the flux field Punch's though and expresses its self on the other side .as it fills it has one polarity opposite to the magnetic source but once filled its over powered by the source a aperance of polar flipping .this is how the Wesley magnetic neutral zone motors worked it needs a wide spread of the polls .you can use two neos on a bar and a bit of plate steel and a compass or a bit of iron stapler opened up.the stapler flips at the reversal point as the compass flips. They used horse shoe magnets back then and only needed 1/15 of a inch of movement to work it .and he made a electrical generator with it utilizing the  flipping polarity.
Ufopolitics
Quote from: jimbo on February 18, 2022, 03:37:11 PM
Hello Jimbo,
Are You saying that Iron-Steel swaps, flips Polarity when facing a Permanent Magnet Pole??
Because the above is completely wrong!!
If you put two neos at each end of a steel bar...depending the polarity you are using towards the steel, you get different results:
1- if you set bar as NEO 1[N/S] [STEEL BAR] NEO 2 [N/S] the steel bar will become as: NEO 1[N/S] [S STEEL BAR N] NEO 2 [N/S]
2- if you set bar as NEO 1[S/N] [STEEL BAR] NEO 2 [S/N] the steel bar will become as: NEO 1[S/N] [N STEEL BAR S] NEO 2 [S/N]
3- if you set bar as NEO 1[S/N] [STEEL BAR] NEO 2 [N/S] the steel bar will become as: NEO 1[S/N] [N STEEL BAR N] NEO 2 [N/S]
4- if you set bar as NEO 1[N/S] [STEEL BAR] NEO 2 [S/N] the steel bar will become as: NEO 1[N/S] [S STEEL BAR S] NEO 2 [S/N]
And no, the steel bar in example 3 & 4 has not become a "Monopole", but just being the host of the Repulsion Interaction between both end magnets poles.
The Steel only becomes an extension of the magnetic field POLE that it is closer to, or touching, or sticking together.
This can be clearly seen with cheap, magnetic viewing film...
Steel is also utilized to "Redirect" magnetic Field Polarity, a clear example is in a car Alternator Center Rotor Steel Core Upper and Lower Claws and Coil at center...
Cheers
Ufopolitics
―Leonardo da Vinci
jimbo
I guess I didn't make it clear   if you use a horse shoe magnet or two magnets with a steel bar or strap connecting them to  create a horse shoe magnet then approach a steel strip a little larger than the set up it will show a polarity of opposite the horse shoe magnet till all the domains are used up then there's no ware for the source to go so it moves though and around the steel strap plate .you can place a paper staple on the steel strap and it will stick there until you reach domain saturation then it flips because of the new conditions .this is the heart of the neural line motors .but mass density of the strap and the fource of the magnets and there distance from each other comes in to play .give a quick test .the flipping is a good indicator .its scalable .
