MY 'LEVITATING OBJECT' INVENTION
Started by guest1289, August 10, 2015, 11:41:23 AM
guest1289
The following is fairly useless,  but it would look great
Imagine boats floating on a  large-flat-magnetic-field (  the field would be curved up at the edges so the boats don't fall out ),   and the boats could have little weights hanging from their keels to give them stability
guest1289
Now I can't work out  why the following idea would not work .
(    I would have thought this idea would have been possible for well over a century,  and that if it was possible,   I would already have seen it sometime  )
(  Obviously the   large-flattish-magnet   providing the  magnetic-field  for the boats to float on,  would have an unusual shape to successfully achieve the effect  )
Idea :
'Imagine boats floating on a  very-large-flat-magnetic-field (  the  magnetic-field  would be curved up at the edges so the boats don't fall out ),   and the boats could have little weights hanging from their keels to give them stability'
guest1289
The  easiest  way to achieve my idea/invention  below,  would be for the boat containing permanent-magnets,   to be repelled/levitated  above  a flat-surface  made of a diamagnetic-material like bismuth
Idea/Invention
Gabriele
I red and saw a video from a russian clever inventor,shows a way to link to magnets without contact...interesting indeed.
You could use that to achieve a way to tracht(traction) two bodies linked witout contact...i don't remember the name of the linkage---
guest1289
Below, are 3 diagrams showing  3  different methods for this  toy levitation idea  .
(  NOTE : This is not the  'Invention'  for which this thread was created,  check the original posts  )
(  I cannot build anything ,  and I don't have any diamagnetic materials ,  etc,  etc  )
