About Perpetual Motion
Started by Gabriele, August 10, 2015, 02:11:24 PM
Gabriele
Gabriele
Answer me please if you can.
SoManyWires
Quote from: Gabriele on August 30, 2015, 05:00:16 AM
by cutting the centre channel shown in the picture on one side,
it would increase transfer flow rate slightly, or reduce the flow rate depending on which of the 2 main chambers held more water in it,
also the pressure from more water at first, would gradually reduce the flow rate until equalibrium was achieved.
take an aquarium and silicon some glide slots for removable boards of different lengths to try in place or even just using tape instead of silicon to help get a more practical understanding of your project designs flow rate effects.
you want to harvest from the force of energy of a ferro-fluid being transferred past wire coils, or even just water, and possibly through rotating fins/turbines placed at the lower fluid transfer points, and more turbines placed on the inside walls of the chambers,
and maybe poured into another vessel that also collects energy like a regenerative braking system as that vessel lowers from its slow vertical fall / displacement?
it does seem maybe possible you could also include what you described for getting some energy from the raising of a float kept inside the center channel itself that maybe causes a shift in weight from a pushrod reaching a fixed angled rocking lever.
as for surface tension, the concept described was lost in translation for me, as much often is. and more often an idea seems to work better as just an idea until real tests are performed.
some sort of balance would have to trigger another action to make one side heavier that needs to be capable of repeating itself, borrowing from the electrical and mechanical energy created if you can keep developing it, there might be something there.
Gabriele
No way.I returned on my steps with adhesion-cohesion forces. Insted of submerging a thin plate of glass in mercury and letting she emerge 90° rotated(so the work due to A/C forces are greater and we can gain energy(?),i thought this system. Consist in a glass capillar with at the bottom a box... When it is all submerged in the mineral,we move down only the box increasing lateral surface,so when the system emerge we should obtain more energy than when we sink it. There shouldn't be Forces against the goal...  experts?
Gabriele
This is the system i'm studying...is simple as you can see.. anyone that will help with the measures?
