Tinman's coil shorting circuit
Started by penno64, September 12, 2015, 05:18:54 PM
tinman
Quote from: gyulasun on September 26, 2015, 05:21:08 AM
Hi Brad,
Thanks for the hints.
I would have two questions here:
1) Am I correct by saying that in your recent RT the created imbalance is further enhanced by disengaging the repel flux from the embedded magnet at the right moment?
2) Considering a solid state version for your recent RT,  the lack of the physical motion of mass would cause the same lack of imbalance, right? If yes, then have you found some 'tricks' to solve this, is it possible?
Thanks,
Gyula
I have not yet found a way to make a solid state version of the RT work,as the magnetic field must be in motion,not just rising and falling in magnitude. In the RT the motion increases as the magnitude decreases-this is the gaining altitude while walking down step's.
In order to make a solid state version,you would have to design a transformer where the magnetic field is not only rising and falling in magnitude,but also has motion throughout the transformer body. It would be my guess that (if it actually works as claimed)the TPU works based around the motion of a magnetic field,not the rise and fall in amplitude.
penno64
Hey Brad,
One final question if I may -
In this video at 2:35 ish you state
https://www.youtube.com/watch?v=fpcqMPvcoW0
the only thing I've done to the motor is "remove some of the spring tension off the brushes"
Other than separate the stator coils, is that statement entirely true?
I would understand if you do not wish to answer.
Regards, Penno
tinman
Quote from: penno64 on September 26, 2015, 09:24:44 AM
Hey Brad,
Regards, Penno
The information given in that video is only what i wanted the public to hear.
It is good to see some used there brain and copied the videos.
seychelles
Hi TINman you are right on the solid state rt.. check my CRESCENDO MEG back few months i posted..
it is all there..ready to be wired up..'easy mieen ' mearcat adv
seychelles
hi all i am back in oz and if anybody got a job for me in perth i will put you in my will.
now here is an idea that i have not tested but will. this coil will by wound on the stator coil of
this motor you guys are testing. this is to reduce the back emf hopefully increasing
efficiency..
