Produce gold from Bismuth
Started by franco malgarini, September 16, 2015, 04:29:29 AM
joel321
QuoteBismuth has a lowish 'profitis point',it can be transmute in a number of ways
I took a look at bismuth pictures and they all look about the same...the rainbow in colors in the crystals. Lots of yellow though. I also saw how bismuth can "levitate" a magnet too. Bismuth is a real phenomena piece of matter to be honest. But I don't see how it can turn to gold at all, maybe just rearrange the molecules to look all gold color only?
The same can be said about liquid mercury? Looks silver in color? Or white gold color? But it does have some strange properties. I see them both as "dark matter"...mostly I see liquid mercury closer to dark matter than bismuth since liquid mercury, although a liquid, can hold up mass than any other liquid? (dense liquid) The dark matter in outer space is some type of dense "liquid/air" that is the layer of space time. That holds up galaxies floating in the space (floating on liquid mercury type?). Bismuth could be said is part of outer space electric universe too. It just depends how you look at things...I think it's called "frames of reference"
part 1 https://youtu.be/Y75kEf8xLxI
part 2 https://youtu.be/dAoGpflOmdw
part 3 https://youtu.be/3ug23VTMies
part 4 https://youtu.be/GzvGfOgf7Y4
In my own personal opinion, it would be more efficient and profitable to dig up gold from the ground than to make it. Turning bismuth to gold sounds to good to be true...if that is the case, turn gold to bismuth?
Pirate88179
Quote from: joel321 on October 03, 2015, 12:41:31 AM
Try using JB Weld.  It can do this.
fritznien
Quote from: joel321 on October 02, 2015, 01:46:56 AM
I have two questions:
1- What is the color in the light spectrum of the output gold?
2- What are the element ingredients in "real" gold?
Lets say your machine makes gold (theoretically) would it have the same principals as real gold a.k.a. 14 or 24 karat? Or will it just have the color gold in the light spectrum?
Either way, it would seem fake (artificial) 'cause that is not how gold is normally made?
bismuth and gold are elements.
joel321
QuoteTry using JB Weld.  It can do this.
lol You need to get paid for advertising JB weld. Let me set a challenge for you bill.
Lets 'weld' two pieces of plastic the same, ok. You use JB weld and I use other methods. Are you up for the challenge? The same plastic that is broken, you JB weld two pieces and I 'glue' them together by my own method and see which holds better?
Do you want to take the challenge?
Pirate88179
Quote from: joel321 on October 03, 2015, 01:47:43 AM
Do you not remember?  I have already accepted this challenge from you and...I have already won.
So, are you requesting a rematch then?
PS  I get paid $1,000 every time I mention JB Weld.  See?  I just made more money.
