Produce gold from Bismuth
Started by franco malgarini, September 16, 2015, 04:29:29 AM
profitis
"But I don't see how it
can turn to gold at all, maybe just rearrange the
molecules to look all gold color only?
The same can be said about liquid mercury? Looks
silver in color? Or white gold color? But it does have
some strange properties. I see them both as "dark
matter"
Its funny that you should mention "dark matter" because this is how lenr works.if you shove all the elements into a black hole each one of those elements will have particular disintergration or intergration points where they either breaks down into more stable elements or re-arrange into more stable elements.I was the first guy ever to give these breakdown/assembly points a name,the 'profitis points'.bismuth is a heavy,unstable nucleus and will be rather sensitive to these  black holes.  I've seen talk about guys dissolving mercury in nitric acid and shoving it into the sunshine infront a magnify-glass(your laser) and getting gold.there's also talk of gold from tungsten but the efficiencies/costs of these lenr conversions are all uncertain.
franco malgarini
We can also produce platinum wires from that reactor
profitis
I'm keen to do experiments with the mercury acetate/nitric acid formula just to see if I can detect any gold.all those gaseous products (NO2/N2O/H2) of reaction are in the NASCENT(hyper-active) states.
joel321
QuoteIts funny that you should mention "dark matter" because this is how lenr works.if you shove all the elements into a black hole each one of those elements will have particular disintergration or intergration points where they either breaks down into more stable elements or re-arrange into more stable elements.
I don't care about the blah blah blah....I just care for someone to explain the "dark matter" once and for all!. If you can't then you have NOT figured out the UNIVERSE so STOP pretending like you do or you should get bullied!
QuoteI was the first guy ever to give these breakdown/assembly points a name,the 'profitis points'.bismuth is a heavy,unstable nucleus and will be rather sensitive to these  black holes.
A guy that told me to suck his dick on the internet is "intelligent" enough. Actually, you don't define "dark matter" at all. Let alone "gravity" NOR "point of reference". I honestly feel like you are trying to explain an answer but I just can't see the solution in your mouth?
QuoteI've seen talk about guys dissolving mercury in nitric acid and shoving it into the sunshine in front a magnify-glass(your laser) and getting gold.there's also talk of gold from tungsten but the efficiencies/costs of these lenr conversions are all uncertain.
If you had one million worth of gold bars, you would not be wasting your time thinking how bismuth can be turned to gold. The manipulation of gold is great with you!!!
-How do you make fire with gold?
-How do you eat gold?
-How does gold make babies?
-How does gold becomes a judge of justice?
-How does gold tell you how to live a human life?
-HMMM gold = money only?
Profitis, you do not intimidate me at all bro.
franco malgarini
