Your help please my DC motor/generator !
Started by zapperone, October 12, 2015, 09:40:13 AM
zapperone
Hello, requesting your professional help please on my DC motor/generator project.
I have built a 16 pole magnetic generator with a commutator and brushes. It works "by itself"
when a hook up 1 - 12 volt battery too it, very very slow. (testing).
My intention is to have it to "recharge itself" as it is
running. What do I need to "get the RPM's up" and maintain them
up under load, and how to run a line from the generator back to the battery (s) for battery
recharging as its working.?
I have heard of a "converter" or something like that DC to DC, or would that apply here and if so how???
Please go "easy" on me with answers, I am still learning. Everything must be gently
explained fully. Thank you so much
Earl
Paul-R
We need to know a bit more about your device. Do you have a circuit diagram and a picture?
A DC to DC "converter" is called an inverter. There is a wide range available working between various voltages and at different amperagesrated as wattage. Also from DC to AC. This sort of thing:
http://www.ebay.co.uk/sch/i.html?_odkw=&_osacat=58288&_from=R40&_trksid=p2045573.m570.l1313.TR12.TRC2.A0.H0.Xinverter.TRS0&_nkw=inverter&_sacat=58288
zapperone
Hello and I thank you for your reply. I have built a 16 pole air coil motor/generator combination which makes both AC/DC current. Right now I am testing it by using just one 12 volt battery only just to see if it will rotate as its own motor. Yes is does !!  I had heard to get it running on its own, then use some sort of "converter" and run a line from the motor/generator to the battery to keep the battery recharged. NOT inverter, a converter !! My intentions are to get it running on its own, which right now it will do with the one 12 volt battery, then get the RPM's up to generate the 120/240 VAC and to "maintain" them for the load, and have the unit to recharge itself in order to keep on working. Any help appreciated !!
God Bless and thanks
Earl
Paul-R
You need to reclaim the collapsing field. Have you studied the Bedini SG and Patrick's book?
http://www.free-energy-info.com/
Check out Chapter 6, amongst others.
garry s
The quickest way to see an output from this is to add a diode to each wire, to stop power input from a second battery and then connect the 2 wires to a bridge rectifier to convert ac to dc and then feed it into a second battery to charge it.
This simple setup shows there is more to this than you have been told and its the thing that got me into this many years ago.
Garry
