Rotating Magnetic Field's and Inductors.
Started by tinman, December 14, 2015, 09:08:53 AM
tinman
Quote from: gotoluc on January 03, 2016, 12:15:37 AM
Why and what will that do for me?
Thanks
Luc
It will show that the !law! of induction is incomplete-although you,i and Erfinder have already shown this. I believe Erfinder had produced this wave form some years back.
We see an increase and decrease in magnetic flux in the core,but the voltage dose not go through the zero volt line as it should. At the point where the magnetic flux go's from increasing to decreasing,you should have 0 volts across the coil.
Brad
P.S  -To be able to make a brushless DC generator without rectification is a great achievement ;)
tinman
Quote from: gotoluc on January 03, 2016, 12:28:32 AM
Humm... never heard of a Halbach array.
You can even get an aluminum ring to hold the magnets in place: http://www.gyroscope.com/d.asp?product=CIRCULARHALBACH
Learned something new.
Thanks and let me know on the other question
Luc
ADDED: I also found a high efficiency motor made with a Halbach array:
http://www.launchpnt.com/portfolio/transportation/electric-vehicle-propulsion/
http://www.launchpnt.com/portfolio/aerospace/electric-machines-for-propulsion/
QuoteI looked it up and they say it's as close to a monopole as you can get.
That is correct,and it is achieved by confining one field within the array,and this in turn expands the other field outside the array.
Do you have a pool Luc-or a decent body of water for an experiment ?
If yes,then you can power a small boat using nothing but the earths magnetic field.
Im sure you will work out how this is done now lol.
Brad
gotoluc
Quote from: tinman on January 03, 2016, 01:12:58 AM
Yes, it was around 10 years back or more (lost track) when I first started experimenting and learning but didn't understand what Erfinder was doing or had found.
I'll look into it a little more but still not sure what the reason or value of keeping the wave over the zero line.
I don't rectify DC motors when I use them as generators, so again not to sure what the value is here?
Thanks
Luc
gotoluc
Quote from: tinman on January 02, 2016, 10:19:56 PM
Yes,the entire wave form is there-one complete cycle.
Now all you have to do is get the entire wave form above the zero volt line without the use of rectifiers ;)
BTW, are you getting this wave from the rotor you've been using in the tests of this topic?
Luc
