Rotating Magnetic Field's and Inductors.
Started by tinman, December 14, 2015, 09:08:53 AM
EMJunkie
I was going to start a new thread for this but instead decided that the topic of this thread really is the same.
I have done a video with a demonstration of how Electrical Energy is "Generated" - Electrical Energy 101 - Faradays Law of Induction - Part 1
F = the Force on the Electron, or the Charge in the Conductor. Forcing the ve+ Charge in the Direction of the Arrow F.
References: Spin–charge separationPhotoinduced charge separation and Lorentz force
   Chris Sykes
       hyiq.org
tinman
Quote from: TinselKoala on December 15, 2015, 08:14:03 PM
Ditto.
I'm wondering what kind of "efficiency" numbers I'd get from this old thing if I used the same measurement and calculation process that we are calling "efficiency" here.
http://www.youtube.com/watch?v=LfC5cTHtfYY
Remember
I made it very clear in both my videos and my post a few post back, that I am refering only to the electrical efficiency (P/in to P/out ratio)
I am not trying to calculate mechanical or heat output in these test.
If you think that there is something wrong with my electrical P/in to P/out ratio and efficiency calculations, then please say so.
If you also think there is a way to increase that electrical efficiency (using the coil I am using)without the magnets in play, then feel free to voice your opinion.
tinman
Quote from: MileHigh on December 15, 2015, 08:58:25 PM
Brad:
I believe that you state in your clip that the rotor has eight magnets alternating north-south-north... facing outwards.  Are you sure about that because your waveforms don't seem to indicate that.
Yes, I am sure about that MH
Things not looking like they should be hey?
Aint that a hoot.
How should they look MH ?
Brad
tinman
Tonight, and over the weekend, I will be building my toroidal version of a pulse motor--> im sure Erfinder knows whats coming up.
I hope all the builders out there put all the pieces together ;)
Brad
Quote from: tinman on December 15, 2015, 11:14:31 PM
Aint that a hoot.
Yes I did a double-take on that one and realize where I went wrong after having a second look at the geometry of the setup.  Your eight-pole rotor looks like a four-pole rotor.
The real hoot is that you are still leading yourself down a garden path and Luc is along for the ride.  You need to put the pieces of the puzzle together and come up with the right conclusion.
How is it possible that a coil that is driving a rotor can be more efficient than a coil that is not driving a rotor?  Conservation of energy is telling you that that makes no sense at all - it's impossible.  The magnets are not "increasing efficiency" - try figuring it out by assuming for the sake of argument that I am right.
Think about it, you are on a forum for energy research and you are deceiving yourself and convincing yourself one more time that "magnets are a source of energy" or "magnets increase efficiency seemingly out of nowhere."  That's why there are all of these unscrupulous con artists out there because it's such an easy thing to do, it's like taking candy from a baby.  Try to figure it out because right now you are spreading disinformation and making it that much easier for the con artists.
