Magnet Orientation ? - Bedini 10-Coil
Started by CompuTutor, January 07, 2010, 10:54:57 AM
CompuTutor
Yeah, on EFTV 6 (Energy From The Vacuum)
"Inside Radiant Energy" starting at about 5 Minutes.
He starts talking about the real 10-coil unit.
He clearly both says and shows the trigger circuit
triggering between the magnets at what he says is
22-Degrees off of magnet pair ("Sharp North") center.
10-Coils/365-Degrees = 36.5-Degrees each.
I'm sure he meant 18.25-Degrees, not 22...
Another interesting unexplained effect happens
at about 1:20 into EFTV disc 2 to the camera.
He is talking about the audible clicking from the coils.
He holds his hands on a couple generator coils,
then puts his hand on the (3-PM) trigger coil.
Watch around his hand and past that coil,
the darkness of the breaker box helps show this.
Wierd stuff.
CompuTutor
Quote from: nightlife on February 13, 2010, 10:59:38 PM
CompuTutor, this should help lift up your spirits.
You are rather new here and most likely missed my topic about using both poles of a electromagnetic coil.
With 61 pages of posts I am at a slight loss without a hint.
This one perhaps ?
"new magnetic motor goes 2000 rpm without load 1000 rpm with load"
I'll gladly read/learn/ponder,
if you would be so kind as to
throw me a clue about which thread.
Thanks
