Looks Like OU Senior Member Avalon Has DONE IT! New Video!
Started by Just..Sayin.., January 16, 2016, 01:09:01 PM
e2matrix
Quote from: picowatt on January 19, 2016, 12:03:32 PM
E2Matrix,
I'm still trying to wrap my head around how the Smartmeter
shown in the tear down video can tell the difference between
a 10 amp at 120V load and a 10 amp at 240V load.
Check out the single current sense coil with only two wires coming
from it.  Also note how one of the legs passes thru the Isense coil
in a direction opposite to the opposing phase.
Also note the small wires coming off the two main legs after the Isense
coil most likely for both circuit power and Vsense.
10 amps at 120V or 10 amps at 240V, how does it know?
PW
Notice that what the guy later states is probably the current sense coil also has a heavy bar going into it and out of it beside the blue and white wires.   That is probably the neutral between the two 'hot' legs and so is a center tap on the coil.
picowatt
Quote from: e2matrix on January 19, 2016, 12:50:34 PM
Notice that what the guy later states is probably the current sense coil also has a heavy bar going into it and out of it beside the blue and white wires.   That is probably the neutral between the two 'hot' legs.
The neutral is not connected to, and does not pass thru the meter in the US.
The neutral goes directly from the service panel neutral bar to the pole transformer center tap
(and a local ground rod).
There are two "bars" passing thru the Isense coil.  These are the two line phases from the pole.
One of them passes thru in the opposite direction to the other which would flip that line's phase.
PW
FatBird
Here is something I have never seen mentioned.  Since the moon has no atmosphere (just a vacuum)
WHY aren't the space suits PUFFED UP as hard as a FOOTBALL?  Nobody has ever pointed that out!
Here is a VERY interesting video that shows 10 reasons they never went to the moon:
https://www.youtube.com/watch?v=qQyS-5ZmO_E
You are really silly.  For one thing, the internal pressure is about 1/3 that of sea-level pressure.
Why don't you actually do some homework on your own before you post your silly conspiracy-theory mishmash?
https://www.nasa.gov/audience/foreducators/spacesuits/home/clickable_suit_nf.html
https://en.wikipedia.org/wiki/Apollo/Skylab_A7L
And as far as the other video is concerned -- I'm sure that one can find all kinds of out-takes from various movies that "prove" the existence of Wookies, light sabers, the Millenium Falcon, space warps and even intelligent raccoons. Have fun! But when you try to denigrate one of the greatest achievements the human race has ever accomplished, and that has all kinds of positive evidence and proofs, you'll have to dissect _every one_ of the positive proofs and somehow demonstrate that they are faked. Which you cannot do. Meanwhile very one of the "conspiracy" claims is easily disproven by real evidence, and all you are left with is stomping your feet, holding your breath and screaming "It's all faked" !!
tinman
Quote from: TinselKoala on January 19, 2016, 05:08:48 PM
And as far as the other video is concerned -- I'm sure that one can find all kinds of out-takes from various movies that "prove" the existence of Wookies, light sabers, the Millenium Falcon, space warps and even intelligent raccoons. Have fun! Which you cannot do.
QuoteBut when you try to denigrate one of the greatest achievements the human race has ever accomplished, and that has all kinds of positive evidence and proofs, you'll have to dissect _every one_ of the positive proofs and somehow demonstrate that they are faked.
I am yet to see any positive proofs that are not provided by NASA.
QuoteMeanwhile very one of the "conspiracy" claims is easily disproven by real evidence, and all you are left with is stomping your feet, holding your breath and screaming "It's all faked" !!
OK,maybe we start with sorting out one simple problem first.
Where are the wheel tracks from the lunar rover in the pictures i supplied--from NASA them self,and one from the link you provided TK.
Brad
