Creating the perfect overunity Scam
Started by Nink, February 05, 2016, 10:24:33 PM
dxer_87
From many years I am interested in sources of energy and low energy devices. I was believing much in Sterling D Allan work. But when i found he is a public person mostly because he is a pedophile, that's very sad. I lost my faith in this man.
My first ask here can magnets have magnetic potential energy? I answered to these questions after years and yes. There is something like magnetic potential energy that is even simple to calculate. You only need a dimensions of a magnet and energy density of it. If you multiplicate one by another, then you have magnetic potential energy. Everything is fine, the units are correct. The only thing is you should divide it by two, because potential magnetic energy is used in most projects only from one side. The proof of this concept are patents land shows like those from Muammer Yildiz. I even tried to enhance this project for easier stopping the permanent magnet motors. I found you can use an electric motor/generator on one shaft supplied by acid battery. This runs as generator when the energy is transferred to electricity and as a break to stop whole device when the coils are powered in the wrong direction from acid battery.
I was amazed that some man from Georgia used such idea and say he is selling such devices. That was possible. But... that was a big scam called Magmov. And this scam is still active. Many invested their money and time for that person.
Another project that proved me that potential energy of permanent magnets is old Searl generator.
Those concepts are very easy, and easy to calculate or understand. But still the common physics books says "magnets don't represent energy". Newton says when apple is holding the ground it has gravity potential energy in vertical. When a child says that a magnet is holding freezer so it has magnetic potential energy in horizontal, he is ridiculed. This worldwide lie won't stay long. Believe me. And yes, you can replicate in your garage the work of Muammer, the work of Searl. That will work and gives you what all we want as bread, the electric generator.
But, getting back to this Newton thought that he argumented by a simple equation of an object dimensions and its density, when these force in vertical is freely available, many tried to use it to produce gravity motor. Those are ridiculued too. So i took a patent and tried to make equations for those motors. And these are very simple to mathematically prove that they must work according to Earth gravity. How to make it? You take an image of motor, you write forces as vectors, then you divide it on the left on the right side cut in the shaft. You calculate the left torque, you calculate the right torque, one must be bigger from another, then you subtract them and here you go, these is torque of your motor. These torque is multiplied by dimensions and you have the average power of the machine. The only condition is that the torques differences must be bigger than friction in any state of the shaft, that problem was pretty done in bhaskara motor. The total torque was almost perfectly stablein any state. (The shaft is horizontal). But still a science is saying nothing smart about those devices or more, it is telling lies that gravity motor cannot work. True physics by true scientists! Very sad. Do the math of solid of revolution. It's very easy, the equations are known and the patents are available. And yes, you can replicate those.
And these is for the beginners I think very good. This shows that we are taught in school many times pack of lies. We saw images of gravity motors with description: this is fail, this was medievial scam. No, it was a great technology that is lost and we need to dig and burn as idiots. The only material for gravity motor is steel and a bit of grease... Keep your research my friends, open your schemes, show your ideas and tries. We must protect those technologies, though we are not earning nor dollars nor bitcoin which I found is a biggest scam of XXI century (about 500 billions of dollars lost for this mafia worldwide, even Asus and Nvidia was fooled...).
Muammer was a good reasearcher and inventor but I think he is lost business and nothing more gonna happen. Don't believe you can buy this. Build your own.
Yours sincerely Dxer from Poland.
F6FLT
Quote from: Nink on February 05, 2016, 10:24:33 PM
So with that in mind how would you create the perfect overunity device that could fool not only the general public but also someone with a Masters in Electrical Engineer or a PhD in Nuclear Physics?
Follow the example of Andrea Rossi!  ;)
F6FLT
Quote from: dxer_87 on January 15, 2019, 06:06:49 AM
You're right. They have a magnetic potential energy, just as masses have a gravitational potential energy. This means that magnets moving from a starting position to a position of less magnetic potential energy will provide energy, and you will need to provide energy to move the magnets back to their initial position. The energy involved in both cases is the difference of magnetic potential energy between the start position and final position. A magnetic potential energy is determined by the configuration of the magnets, in particular by the topology of their magnetic field in space, which has an energy density B²/(2*µ).
It should be noted that, as with any potential energy, the work produced or consumed to move from one position to another does not depend on the path, but only on the difference of potential energy between start and end position. No energy gain can be obtained from the potential energy in a cycle: since the start and end positions are identical, the difference of potential energy is zero, so there is no cause for the magnets to move between both.
F6FLT
Quote from: F6FLT on January 16, 2019, 03:45:58 AM
Quote...
May be I'm wrong !
https://animpossibleinvention.com/2019/01/16/the-moment-of-truth-is-getting-close-with-launch-on-january-31st/
