HHO Generation using High Frequency electromagnetic waves on water
Started by Panos25, February 24, 2016, 10:25:55 AM
kolbacict
QuoteSwitching times can be improved by doping of the electrodes with radioactive isotopes caesium 137 or nickel 63,
and by orienting the spark gaps so that ultraviolet
light from a firing spark gap switch illuminates the remaining open spark gaps.[3]
understandably. that's better.  :)
Only i still take doubts whether the upper water capacitor be able  charged through a chain of resistors with a resistance of tens of megohms.
But an amazing idea came to me, how to give up  resistors for charging . :) ;)
I will draw, I will show ...
stivep
QuoteYou may be thinking that water is a good conductor of electricity but remember that only
water with ions present conducts electricity.
Deionized water (water with all ions removed) is actually a poor conductor of electricity.
The dielectric constant of pure water at 20 degress C is 80.1.
https://www.enotes.com/homework-help/what-dielectric-constant-water-375624#:~:text=You%20may%20be%20thinking%20that%20water%20is%20a,pure%20water%20at%2020%20degress%20C%20is%2080.1.
so we have two factors :
1. temperature
2. deionization
_____________________
But we also have the third one :
- impurities in the water.
so water needs to  be distilled .
_______________________________________
What is the dielectric constant of water?
QuoteA dielectric is a material that will polarize itself when subjected to an external electric field.  The dielectric material itself is not a true conductor of electricity.  But the partial positive...
__________________________________________________
https://nvlpubs.nist.gov/nistpubs/jres/56/jresv56n1p1_A1b.pdf
Quotecapacitance-conductance bridge, operated at frequencies below 100 kilocycles per second, was used to measure:
-the dielectric constant of water with an accuracy of better than 0.1 percent at 5-degree intervals over the range .0° to 100° C.
At 25° C the dielectric constant was found to have the value 78.30,
which is about 0.3 percent lower than t hat usually accepted.
The data fit the equation E= 87. 740 - 0.400081+ 9.398(10- 4)tL 1.410(10- 6)13, with a maximum deviation of 0.01 unit in dielectric constant.
The experimental method and sources of error are considered in some detail.
Wesley
stivep
So how good is water as dielectric is one question?
the other question is : how good is water as isolator.
as  some of you dont  always  see the difference  between the two.
For more practical approach we need to look at  EDM  machine.
it does  "miracles"  to the  conductive materials .
but this is just easy way to  play with almost the same schematic  when playing  with HHO
the article explaining it is here :
https://www.sciencedirect.com/topics/engineering/deionized-water
the practical use  of the  EDM  go here:
https://youtu.be/4iB7kkCy1xM?t=141
some of the wire  EDM could be  acquired  in  USA for $100 in working condition.
I had one in my  mechanical part of the lab.
https://youtu.be/DNxob3yY4LE?t=25
https://youtu.be/2dsrLD52Mv0?t=885
just don't believe in this video to the statement that  precision machining with EDM costs  as much as a house in USA.
THIS IS NOT TRUE.
SO WHY HE IS SAYING IT?
BECAUSE HE  IS LIKELY NOT AN AMERICAN
There is  the difference between  a British experimenter as  well as EU
and us the AMERICANS  - we are over-saturated with everything and sometime it is a need  just to take it...
Yes... some guys wants you to take  it for  free..
In some  very much democratic countries making scrap  from tools, measurement equipment and  and machines  is impossible,
if there is  any, means anyone willing to buy it for more than 0 dollars.
But in some countries   having 'per capita"  at level of "third world countries "   in  Eastern part of Еurope  it is quite different story .
And Russians?..................
Russians  unfortunately can dream about   earning  additional 25 dollars more
per month in addition to their monthly  175 dollars average salary in regions.
African Uganda is $280/mo
Papua New Guinea  average is $195/ mo
https://youtu.be/Rq8SA3AB06k?t=130
Here is some  Papula technology to enlarge  human male  reproduction organs.
I hope some  Russians can learn  something  from that as it is inexpensive and easily accessible .
There is still in average  1 per every 10 000 Russians who speaks  at least some English there  but,
I can help  with translation if needed.
I'm not   professional in this area but it is interesting  how it works from science based  stand point.
Wesley
stivep
Quote from: kolbacict on April 22, 2021, 02:39:25 PM
The schematic posted by you will likely  not work.
The same core is sharing  windings from each stage including  the first  coupling with generator.
It will  blow  in no time. ( "no time " -is an idiom)
Can you correct me if I didn't understand something?
Wesley
kolbacict
Quotehttps://overunity.com/16440/hho-generation-using-high-frequency-electromagnetic-waves-on-water/dlattach/attach/181267/
Really awesome. :)
QuoteThe same core is sharing  windings from each stage including  the first  coupling with generator.
Well, the windings are separated by very good insulation.
Similar to how it is done in split transformers from TV.
p.s. May I ask again why everyone thinks Stanley Meer is dead?
p.p.s. Here's more on the topic of Marx's water condensers.
http://elib.biblioatom.ru/text/ucheny-mechtatel-borets_2006/go,325/
