HHO Generation using High Frequency electromagnetic waves on water
Started by Panos25, February 24, 2016, 10:25:55 AM
Sergh
Maybe in nanostructures superconductivity and "superinsulators" are possible.
Quote from: Sergh on June 05, 2021, 11:35:51 AM
Not an answer but a step-by-step help by others :
https://scholar.harvard.edu/files/chaochen/files/7-2013_microfluid_nanofluid_brownian_motion-induced_water_slip_inside_carbon_nanotubes.pdf
f.e.
"   .... , there is no critical interfacial shear stress to conquer, and water could slip inside CNTs under any given pressure drop due to the thermal activation at room temperature. ..."
conductivity
enforced c.
deforced c.
superconductivty
isolator
the physical "term" amplitude(max/min) defined
How small this here offered process can become micronized :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=28&ND=3&adjacent=true&locale=en_EP&FT=D&date=19920507&CC=DE&NR=4035445A1&KC=A1
ramset
Quote from ACCA earlier in this topic
""About 2 years ago I studied the Zographos videos and in one video he had a spectrum analyzer
the display had shown the the upper end of a 300 Ghz. which was quite a shock to me as I worked on radars on slightly lower frequencies.. In the glass test test tube he had placed a small metal plate. Some of the invited scientist passed around the small metal square plate, they where quite surprised, as the device would not work with out the metal square plate in the test tube.. and some years earlier another RF guy John Kanzius used an RF exciter 13.75 Mhz to split water in between two antennas again in a test tube with a tissue immersed wick and the gas would light the wick with a yellow flame as Zographos did it on Greek TV for hours at a time.  The point is that RF in it's self break's up water bonds, the question is what frequency is the best and what modulation is needed to do that.. Now I have split water with RF at 750 KHhz as using a Russian Tesla coil (katcher) a single transistor RF oscillator with some 10 watts of power and was surprised that it worked as it involved high frequency diodes and a test tube. I will post a video later of that..In closing I am surprised that Zographos is still around with incredible knowledge that he has amassed in his RF field in Cell phones.. SO I have posted here on another thread today about this New Zealand company they also have a cheap way of splitting water and it is 20 times less than the conventional electrolysis RF may be a contender as well as graphene.. This none of these tech(s) will NOT see the light of the day, unless it is opened sourced to the people..
Acca..
End quote
Ps from ... https://m.youtube.com/user/FleischmannMemorial/videos
A bump
And a hobby worth sharing??
Respectfully
Chet K
Thanks Grandma
kolbacict
QuoteNow I have split water with RF at 750 KHhz as using a Russian Tesla coil (katcher) a single transistor RF oscillator with some 10 watts of power and was surprised that it worked as it involved high frequency diodes and a test tube.
Why can't I succeed? Nothing is splited. Nothing comes out?
ramset
https://m.youtube.com/watch?v=bZdX5Hhk9r0
Carbon free steel using hydrogen
Being done by Volvo and Mercedes and ...
Enormous ...humungous reduction in carbon generation during manufacture
And water is the waste ......
See process description at 4 minute mark in vid
97% less carbon
ACCA
Please help !!
We need to have more "clean water is waste product
Of process"
After work is done
Respectfully
Chet K
Thanks Grandma
