HHO Generation using High Frequency electromagnetic waves on water
Started by Panos25, February 24, 2016, 10:25:55 AM
Sergh
Quote from: kolbacict on June 06, 2023, 06:11:49 AM
Does the so-called spontaneous human combustion happen ?
But there aren't any NMR machines around. And in general, when searching by the names of the participants, nothing is found except for a couple of dubious sites.
ChatGPT:
QuoteThis article is on the FernFlower Group website and contains a description of an unexplained fact provided by a witness or published in the media.
It is not confirmed by any official sources and cannot be used as evidence.
However, you can ask nix85, but in another topic.
Yes, please keep this topic straight ontopic and not offtopic with no mysterious stuff about "burning humans"...
Many thanks.
Regards, Stefan.
I have to read more on hellagen.gr with a translator to see the latest posts from Zografos there,he also has something there about fuel cells...
Maybe he is really a stack of a fuelcell in his 20 LED Lights Demonstation..
For what do you think he uses these Thermostats ?
Do you think the water is getting hot in there ? At least he has a fan also blowing onto his copper spiral pipes, so I guessthe thermostats are to switch off the current if it is getting all too hot ??
Regards, STefan.
Here is something about Fuel Cells on his websites:
https://www-hellagen-gr.translate.goog/epistimoniki-dikaiosi/?_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
And here is something from this page especially for Wesley ( user Stivep ), who always says, that Carnot can not be broken and no OU is possible  ::) ::) :P :
And this is because in Greece, as early as 2016,  Petros Zografos  clearly referred to the possibilities of bypassing the second law of thermodynamics and non-application of the Carnot theorem, while he also published a related analysis-study entitled "Bypassing the Carnot restrictive provision of the 2nd law of thermodynamics" in the journal  Physic News  (issue 24, September 2018, pp. 32-37), published by the Union of Hellenic Physicists (E.E.F.).
Petros Zografou's scientific findings on the possibilities of circumventing Carnot's theorem, the second law of thermodynamics, which formed the theoretical basis of the great invention, were met by some representatives of the "holding" academic and scientific community with contempt and discredit, since neither more nor less it was considered that the second law of thermodynamics is always applied, forgetting of course what was said by Heraclitus "everything says and nothing remains"...
The bright exceptions of independent scientists but also of the Union of Greek Physicists, which was the first to accept the scientific documentation of Petros Zografou, were not enough to push young scientists in particular to corresponding research for the benefit of science and innovation, but also of Greek society in general. since our country could take the lead in applied scientific research for the production of hydrogen and consequent electricity.
Sergh
Quote from: hartiberlin on June 06, 2023, 05:43:39 PM
About "copper spiral pipes":
https://c8.alamy.com/compde/hrnrp3/destillation-mit-einem-metallischen-noch-1892-hrnrp3.jpg
but:
https://www.advocard.de/streitlotse/internet-und-konsum/schnaps-selber-brennen-regelungen-ab-2018/
I also don't quite understand what is so hot there, but copper coils, as for moonshine, are often found in Zografos installations.
Presumably, the upper thermostat turns on the copper spiral fan when the temperature exceeds the set one.
If you think deductively, why did Zografos get the idea to install such coolers, similar to the coolers of the moonshine still? Probably because this cooler of his performs a similar function, the cooler condenses the steam.
Probably the gases after the reaction are wet, and he needs to separate the gases from the water vapor.
Quote from: hartiberlin on June 06, 2023, 05:52:18 PM
Stefan, we don't know what this is about.
  Zografos is not a scientist. He can say and write anything, but does he have the fundamental knowledge of everything to assert the truth of his ideas? It takes more than Einstein to defeat the 2nd law of thermodynamics and the Carnot cycle.
What is this, the invincible 2nd law and the Carnot cycle in general?
In a primitive sense, according to these laws, it is by no means possible to create, for example, a heat pump that could at least work without supplying any energy from outside. For example, it is impossible to make your refrigerator work only on the energy of the heat pumped out by it from the internal chambers. He definitely needs electricity from the outlet.
In a global sense, this is the concept of the inevitable increase in entropy in our Universe. Every process in the universe occurs with the dissipation of energy from a denser state to a less dense one. No one has ever observed the reverse process, in the end it all comes down to dispersion and chaos.
https://www.youtube.com/watch?v=FMJNta-okRw
But where does energy come from in our world? Where did some ordering and separation come from, in the first place? "Big Bang"? Was he? If not, then what?
Let's assume that before the times that are supposed to be the beginning of our Universe, "time in space did not flow".
But time is a fundamental parameter of our world, our space cannot exist without time. Probably both space in its current form and solid matter did not exist then. Until something happened. But what?
The problem is that we cannot think in terms that go beyond the stereotypes of our space and time.
https://www.youtube.com/watch?v=d9Unv1xT1FM
Dear participants of the topic!
Take a constructive part in the discussion!
Do not overestimate my abilities and do not underestimate yours!  :)
kolbacict
