Common batteries are free energy sources
Started by Tesla_2006, October 30, 2006, 07:57:12 AM
hartiberlin
Hi Joe,
this probably will only work,
if you switch the setup between
the 2:1 and 1:2 battery setup
back and forth pretty fast.
The idea behind it is not to give
the electrolyte enough time to move inside
the battery, but external electrons, cause
they are smaller and lighter, to move...
So better pulse the setup back and
forth with relays and see, how much longer
you can get it to last...
or use the motor to drive a simple selfmade
commutator, which will switch back and forth.
Many thanks.
Am looking forward to your results.
Stefan.
FreeEnergy
im not sure exactly but i remember reading something about making the terminals of a battery longer/extended and then you would wrap coil around it - something to do with the earth's magnetic field and the sky's magnetic field working together with the battery setup. im not sure but it was something like that.
anyone heard about something like this before?
pese
He Joe.
Silicon Diode dof 0,6 to 0,8 Volt  (even 1 volt if "surged" maximal Power.
Take Scottky Diodes 0,3 -0.5 Volts drop  (from old Computer power Supply (for example)
Or Germanium Diodes (gold bondes diodes) as 1N270 enz.
(you find it in als Computer Platines fro 20 jears ago - or take aold Germaniumtansistors . Collector and Base - Connection only  (GE-Transistor you find easyly.
Germanium Devices hav an Vo?tage Drop fro 0,1 to 0,3 Volts
Pese
qbjorn
A good reference on Tesla 4-battery setup (and Bedini mods) is available at http://www.web-space.tv/free-energy/, select 'Devices Part3' or just click http://www.web-space.tv/free-energy/D3.pdf if you don't want to browse the rest of the excellent material.
Kator01
Hi Joe,
what is the capacity of all three batteries ? You will need this for your calculation. Also you must do a permanent  monitorig of the motor power-consumption.
Kator
