Bedini Circuit with Capacitors
Started by earthbound0729, March 16, 2016, 12:07:16 PM
earthbound0729
Hello Everyone,
While doing further experimentation and reading concerning my Bedini setup, I have discovered that the electricity generated through the magnetic field collapse on the main coils is actually AC, about 7.5 volts using a single wire off the 8 filar wind. I use a simple 12 volt 18AH  sealed rechargeable battery to set everything in motion with DC power.
Regarding this phenomena, then seeing the next logical step of adding the capacitor(s) in front of the Charge battery on a 2 battery system, should a bridge rectifier be used ahead of the electrolytic capacitor to convert to dc first?
Thank you for your insights and suggestions.
earthbound
citfta
earthbound0729
tinman
Quote from: earthbound0729 on March 16, 2016, 12:07:16 PM
Hello Everyone,
earthbound
The collapsing magnetic field will only produce a DC current.
What you have done,is use one of your windings from your !8 filar! (why are you using 8 windings?)coil setup,and you are picking up both the current flowing into the other 7 windings(magnetic field building),and also the current flow caused by the field collapse when the current stop's flowing into the other 7 winding's. This will give you a sine that has one long half wave of low voltage,and the other half of the sine will be shorter,but with a higher amplitude.
So you will need a FWBR on that coil to convert to a DC current flow.
Brad
Hello Everyone,
earthbound
If you want a real answer, please post a schematic of what your existing setup is, and also please post a schematic of what you mean by adding capacitors to the front of the charge battery.  You simply cannot discuss electronics verbally, especially when you are a beginner.
