Mechanical Resonance (Projects)
Started by Magluvin, March 25, 2016, 08:01:12 PM
Magluvin
Quote from: Erfinder on April 30, 2016, 06:07:11 AM
For what it's worth....here is my recommendation.  I really hope you see and can appreciate what this text and illustrations are suggesting.
http://www.google.com/patents/US5625241
Got sidetracked with work. So hadnt posted in a bit.
I really like the way that the magnet arrangement helps to get all sides of the windings fluxed.   ;D
getting some time to do more here.
Mags
Magluvin
All...
So far Im caught between the possibility of... Its either the resonant go between that caused the gain in voltage on the pickup coil compared to the drive coil, which are identical, or the different positioning of the mags per coil.
When adjusting the drive coil/mag position for best throw of the pendulum, and then positioning the pickup coil/mag, they were different slightly to get the results of higher voltage out than in. I will have to take some picks to show the difference. When the coil/mag positions are the same, the output voltage is less or close to equal. So it is possible that a motor and gen just need some differences in order to get a gain.
Another common sense thing that has me leaning toward the coil mag positions being the advantage is, if the mechanical resonance were the advantage maker, I might think that the advantage may be much greater than what I had gotten so far. Working on a test to eliminate the mech resonance portion of the coils and mags to see if there is the same advantage. If the advantage disappears in a large way, then the mech resonance is probably good to be included.
I had said in another thread that its possible that if we had 2 identical dc motors connected shaft to shaft, naturally we get less out than in. So there may have to be differences in how the 2 need to be reconfigured, with the same mags and coil winding specs, just in a bit different manner/config to gain an advantage.
Mags
Magluvin
What Im suggesting is this possibility....  Say we have 2 identical motors, one can be made to be a better motor and the other to be a better gen, using all the same mags and amount of wire for the windings.  ;) And if the mech resonance is also needed, then it does. If not then this is what Im suggesting thus far.
Mags
