MetaQEG- An invitation to TinselKoala to a cooperative build.
Started by Meta, April 03, 2016, 12:09:51 AM
conradelektro
Quote from: Meta on April 06, 2016, 03:15:18 AM
Which of you losers wants to build it and prove Bearden and myself wrong...its your perfect opportunity....Do you realize its not Beardens circuit any more? Its Bearden with a twist.......or do you fall under my warning as quoted in my original offer.....
It has been said very often in this forum that negative proof is not possible (or better said: a negative proof is a logical fallacy), but I want to repeat it for Meta and all people who still do not understand what can be proved and what can not be proved.
Look at this web site, it explains very clearly why Meta is wrong by demanding "Bearden or himself should be proved wrong":
http://www.qcc.cuny.edu/socialsciences/ppecorino/phil_of_religion_text/CHAPTER_5_ARGUMENTS_EXPERIENCE/Burden-of-Proof.htm
https://youtu.be/KayBys8gaJY (if you prefer to watch a video explaining the burden of proof)
For all who can not read and understand the above web site, I explain it in very simple words:
- One can not prove that Bearden's MEG does not work. Whatever one builds and if it does not work, someone can claim that an essential feature has been overlooked or that it was implemented in a wrong way.
- But one could prove that Bearden's MEG works indeed by demonstrating a working MEG. Of course the demonstration must be clear and measurements must be verifiable by third parties.
Said in even simpler terms: The burden of proof is with Bearden or Meta.
Greetings, Conrad
verpies
Quote from: conradelektro on April 07, 2016, 09:07:17 AM
More precisely an existential negative proof is a logical fallacy.
This happens because:  the lack of proof of existence, is not a proof of non-existence.
verpies
Quote from: tinman on April 07, 2016, 06:54:31 AM
Then maybe--just maybe,some one will have the time to waste...
It is not only about time.
To make a SPST bilateral switch that switches-OFF high voltage below 10ns costs ~10kUSD.
...and switching-OFF below 1ns costs at least ~100kUSD.
But the MetaQEG requires two SPDT bilateral switches, with unknown delays between the throws (MBF?).  You can only guess how much that would cost!
P.S.
Switching ON high voltage with speeds around 1ns is cheap because an ordinary spark-gap can do that.  Krytrons and Sprytrons are better of course, albeit not cheap ;)
Meta
Quote from: AlienGrey on April 07, 2016, 03:21:38 AM
Calm down Meta   your sounding just like that Atom guy, Go back and read your reply to each comment you have I'm sure it says much about you!
life is for learning and control is Satanic demonic even.
Since when did my thread become an examination of the messenger rather than the job I give to you to examine the message, which you consistantly fail to do.
You assholes consistantly turn every thread into the erroneous premise that
If the messenger is a saint, the messengers device will work.
If the messenger has errors, at all, the device is unworthy.
Listen up assholes, my devise doesnt care who I am and I will be anyone I want to be, toward you.
