MetaQEG- An invitation to TinselKoala to a cooperative build.
Started by Meta, April 03, 2016, 12:09:51 AM
Meta
I have an idea based upon Tom Beardens overunity circuit with my additional  gravity concepts added to his circuit, using 40 years of research notes and information gleaned from 39,500+ books of every subject and discipline. My input may give you information you may have never heard of even with your experience using measuring equipment. I am fluent and cognizant in all of physics and metaphysics.
The MetaQEG deliberately bypasses all (e) electric, (m) magnetic and backEMF problems using the counterwound coils and accesses the third force, gravity, which is not in the 3rd dimension.
Im giving you, TinselKoala, permission to work with this MetaQEG PDF (pages 1-3) and build a circuit according to its design and with my additional, ongoing input, all documented here on this thread for all to see, so we have a record.
I cannot build seeing I have no measuring equipment nor a home that allows such projects. You will be building it with my permission and I will be the holder of the copyright of the written posts and pdf material. We will share equally, any prize monies from OverUnity.com resulting from your successful building of the MetaQEG and it will give you a chance to claim the MetaQEG does not work, if you fail to build three working models, two of which shall be delivered to J. Naudin for testing according to OverUnity.com policy and protocol.
The two coils are caduceus coils which, Ive noticed, only you are familiar with, so you will have no major problem in construction of them, on 2 rings of 8 inch diameter styrofoam, 1 1/2 inch thick. You can get about 4 turns on this core on one go around, keeping all dual windings at 90 degree crossings. Use as much wire windings as you wish to.
Remember, to criticize, before through research, is the height of stupidity.
conradelektro
Quote from: Meta on April 03, 2016, 12:09:51 AM
The hight of what is this?
Because you are fluent and cognizant in all of physics and metaphysics, you should have been able to draw a conclusion after 40 years.
I guess you read the wrong books and research notes. If you are lucky, you have an other 40 years to get it right.
Greetings, Conrad
P.S.: Sorry for the sarcastic comments, but the temptation was just to great. You are the first one claiming to be  fluent and cognizant in all of physics and metaphysics. Counting 8 hours reading time per book, 40.000 books means about 37 years of reading (straight through, no breaks). A most strange claim as well.
tinman
Well you have failed before you even began,as Tom Bearden never had an overunity circuit. ::)
Brad
Meta
Get off my thread, presumptuous assholes.
And it was 6 books a day for about 18 years....
memoryman
Name calling is the result of reading all these books?
"I have an idea based upon Tom Beardens overunity circuit.
Brad"
Of course, neither did anyone else...
