MetaQEG- An invitation to TinselKoala to a cooperative build.
Started by Meta, April 03, 2016, 12:09:51 AM
Pirate88179
Quote from: tinman on April 04, 2016, 08:48:19 AM
I have an idea based upon Tom Beardens overunity circuit
Well you have failed before you even began,as Tom Bearden never had an overunity circuit. ::)
Brad
100% correct.
Quote from: Meta on April 03, 2016, 12:09:51 AM
I have an idea based upon Tom Beardens overunity circuit with my additional  gravity concepts added to his circuit, using 40 years of research notes and information gleaned from 39,500+ books of every subject and discipline. My input may give you information you may have never heard of even with your experience using measuring equipment. I am fluent and cognizant in all of physics and metaphysics.
The MetaQEG deliberately bypasses all (e) electric, (m) magnetic and backEMF problems using the counterwound coils and accesses the third force, gravity, which is not in the 3rd dimension.
Im giving you, TinselKoala, permission to work with this MetaQEG PDF (pages 1-3) and build a circuit according to its design and with my additional, ongoing input, all documented here on this thread for all to see, so we have a record.
I cannot build seeing I have no measuring equipment nor a home that allows such projects. You will be building it with my permission and I will be the holder of the copyright of the written posts and pdf material. We will share equally, any prize monies from OverUnity.com resulting from your successful building of the MetaQEG and it will give you a chance to claim the MetaQEG does not work, if you fail to build three working models, two of which shall be delivered to J. Naudin for testing according to OverUnity.com policy and protocol.
The two coils are caduceus coils which, Ive noticed, only you are familiar with, so you will have no major problem in construction of them, on 2 rings of 8 inch diameter styrofoam, 1 1/2 inch thick. You can get about 4 turns on this core on one go around, keeping all dual windings at 90 degree crossings. Use as much wire windings as you wish to.
Remember, to criticize, before through research, is the height of stupidity.
I am afraid there is nothing I can do to help you. You are clearly reaching far beyond anything I might be capable of.
QuoteIncorporated in the switch are the two single pole/double throw switches. This one Fast Switch chip
must be rated at the Relaxation time of the electron. This is far faster than 1ms as designated. It should be in the GHz or
nano/picosecond range.
There are a few other problems I can see in your pdf, but it's not necessary for me to go into them here. You should have your idea reviewed by someone more "fluent and cognizant" in physics and metaphysics. Maybe you can get TheoriaApophasis to help you; he's the only one I know of that might have the right qualifications.
Thanks for your... er... "offer" anyway, and good luck.
ARMCORTEX
An invitation that goes like this: Tinselkoala will build things and I will broom the lab, split 50/50, deal?
AlienGrey
Strange ainit how things keep repeating on the QEG negative equity disposal? How many times can salesman reinvent them self ?
Meta
Quote from: TinselKoala on April 04, 2016, 10:58:21 PM
omitted
Re: TinselKoala
Come on Sir,
I dont bite unless you turn tail and make outrageous claims why you can't do it. You're very close to what this project is about, anyway. I can almost see the gravity beam in the center axis of the caduseus tube affecting the radio in the Faraday cage, instantly....you just have to bend the tube into a ring, a toroidal ring, and you will have captured the gravity beam running in the axis of the ring just like in the centers of Leedskalnin's motor or the Ankh (PMH).....you're gonna head in that direction anyway, you know. Once the ring is formed, you will have a gravity field of potential around the ring, or the dual rings in the case of the MetaQEG, which nothing can stop, in its communication with loads or with another dual, toroidal coil/gravity receiver. Please reconsider before I go through the lenghty process of trying to contact TheoriaApophasis.
PS, Dont look down the axis of the caduseus tube beam...one tube end beam is death, the other end is life.
