My 'Magnet-Motor-3.5', is Censored, on all the Internet-Search-Engines
Started by guest1289, April 11, 2016, 03:24:30 PM
guest1289
conradelektro
   Thanks, I will try your suggestions
   But  Censorship  does seem to be the reason,  because :
     -  Searching for  "magnet-motor-3.5"  brings up the webpage you are currently reading,   and yet it was created some time after I posted this particular  magnet-motor .
     -   And,  'all' of my other designs that I have posted on this website do appear in  search-engine-results
conradelektro
Quote from: guest1289 on April 18, 2016, 02:33:11 PM
The search engines (Google and others) can not update their data bases within minutes. It takes many days and sometime months till the contents of a particular web site (e.g. your magnet motor web site) end up in the data bases.
Specially if your web site is ill designed and has comparatively little content (may be just one page) it will not be discovered soon by the automatic search bots of the search engines. Therefore Google offers the possibility to enter your web page manually as I suggested.
If your web page is ill designed and very low on content it will also be ranked very far down in the search result. When you did your search for your magnet motor, it is possible that it appeared on page 20 of the search result or even further down and you did not spot it. The search for "magnet motor" produces an endless list and your magnet motor was may be ranked near the end of the list.
Nobody censors you, you are much too insignificant. (I am also much too insignificant, in case you are offended.)
Google uses an automatic system (search bots) to gather information from the Internet. There is no human behind it, who filers some one out. There might be important political issues (like political correctness) which are taken into consideration, but no technical issues like "magnet motor". Magnet motors do not interest the main stream and therefore nobody gives a damn about them.
If you want a video of a permanent magnet motor then do the search "permanent magnet motor" in YouTube. (But they all do not really work, unless you are easily deceived.)
A search in Goole for "permanent magnet motor video" also gives you hundreds of videos as a result.
I am afraid you are suffering from some delusion or you can not do a search properly.
Something for you: Paranoia does not protect you from persecution!
Greetings, Conrad
guest1289
     Yes, I have often spent a lot of time looking at   'magnet-motor'  videos on youtube and the other websites .
   VERY LATE EDIT TO THIS POST - EVERYTHING BELOW IS EDITED
    I have just posted another  magnet-motor  :
     http://overunity.com/16298/my-levitators-and-bearings-and-other-designsinventions/msg481274/#msg481274
      This will test how long it takes to show up on the search-engines .
    In the past,  I have noticed that things I have posted on this website,  show up on main search-engine within hours( less than a day ) of me posting them.
     That seems to have changed now.
______________________
    Also, I have now posted  Magnet-Motor-3.5  onto that same thread above,  to see if it shows up on search-engines
    http://overunity.com/16298/my-levitators-and-bearings-and-other-designsinventions/msg481268/#msg481268
conradelektro
Quote from: guest1289 on April 18, 2016, 04:43:08 PM
Now I see why you are censored by Google! ;D You try to give away the greatest and most important secret ever.  ;) Of course that must be prevented. :'(
People are trying to build a permanent magnet motor for about 1200 years and you are doing it left handedly. That definitely should not be allowed to happen. I hope Google manages to filter out your web site and your posts. :o
Greetings, Conrad
P.S.: Finally a chance to use emoticons.
Paul-R
conradelektro
Learn how Google works before you criticise it for censoring you.
