Any ACTUAL OU devices on this whole forum
Started by Permanente, May 17, 2016, 08:10:37 PM
memoryman
" pre maid " lol. Does the maid have to be a virgin?
AA is a size, not a type of battery. Alkaline batteries have very limited recharge capability.
Your device is certainly NOT OU.
jimbo
Very sorry got this email and I'm here know .the idea of a cap string being OU is out there Ben Franklin talked about it and called it cascade charging .the old men of that time said there wasn't any increase in value .but I've read in physics on static induction cascade charging that to that to happen on severl caps in series each is becoming polarized by the charge on one end ..a strong charge is required positive and the other end connected to a good earth ground . now that being said .there's some things going on here that might be confusing ..one is you need a pretty hi voltage positive source I used a car coil .that pretty high..and the voltages are different in each cap due to some kind of shift in each cap. The capacitance in each is different do to being in the string ...I really don't know why .but it's there even n simulations.but that being said the physics people said that it's a one for one electron shift from one side of the caps due to the frount charge .one for one times like five caps .the frount charge pulls from the cap next to it to balance out the fource and there by butting the next cap out of Ballance .or polarizing it .this continues down the line to the end and that pulls from the ground .so here we are a string of polarized caps all charged ou p by the first plate .if it took a billion positrons on the first plate.is going to pull a billion electrons from the next plate to neutralize the charge .and all the other plates do the same .now how do you get the Energy out ? By shorting out each cap though something like a battery or another big cap ..the energy's there .I got up to five capspoping off there neons and shorting themselves out .but the color changes in some occasionally and it was wight with blue not yellow orange so I stopped .a little freaked out .there's great resistance in the cap string and capacitance changes in the strong so what to do ? Get much larger oil caps .and you got your capacitance back .voltage drives the pulling and has to go Thu all of them .in theory it should work .and mine was firing off those caps .and a change can't cross a cap or its a bad cap this is all electrostatic induction .or attraction .just like magnetic induction poloizes a piece of iron this polarized caps using one set of high voltage positive positrons that replicate in each cap .allso it's a little dangerous if you don't get that energy off before you reach the catistofic dialectic breakdown ...boom ..it's a land mine .so I use neons for earth and pull out energy at a lower level..you might get supper caps to work in a string but watch the voltage or boom .good luck..
jimbo
That's I use neons for safety one on each cap .and it you can't charge a cap a single cap with a positive one one end and the other to ground you wount charge more ..either your earth  grounds no good or you cap is they sometimes have bleed resistors in them .charge it up and see if it holds the charge .also a high impedance volt meter is good so you don't drain off power while checking on the voltage .
