Does Dielectric Displacement Current generate a magnetic field?
Started by Reiyuki, May 22, 2016, 01:15:27 PM
Does Dielectric Displacement Current generate a magnetic field?  (paradoxical properties of displacement current)
Yes, it does
5 (100%)
No, it does not
0 (0%)
Other (explain)
0 (0%)
Total Members Voted: 5
myenergetic
Quote from: Reiyuki on May 22, 2016, 01:15:27 PM
Here's the question for everyone:
  "Does displacement current generate a magnetic field?  If so, where and at what angles?"
Hi there
Here is my take on the issue.
In order to try to address your question, the question should be properly defined.
1, If your question is based on the Maxwell displacement current then "Maxwell displacement current" either in vacuum or in dielectrics, neither generate magnetic field nor are sensitive to external magnetic fields. In other words current in dielectrics "The polarization current" does not act with potential forces on other currents and "external magnetic field" does not react with kinetic forces to the action of other currents.
2, Displacement current is a quantity appearing in Maxwell's equations that is defined in terms of the rate of change of electric displacement field. Displacement current has the units of electric current density, and it has an associated magnetic field just as actual currents do. However it is not an electric current of moving charges, but a time-varying electric field.
To conclude the above I quote from
"Harry McLaughlin" https://www.quora.com/profile/Harry-McLaughlin
a. A "changing" electric field CANNOT create a magnetic field
b. A "changing" magnetic field CANNOT create an electric field "end of quote"
3, The so-called "displacement current" term(1/4π)  ∂E/∂t  is not some current density generating magnetic field, as Maxwell supposed. This term gives information about the conduction currents which have been interrupted in the neighborhood of the reference point.
4, For what it worth, we cannot measure magnetic field produced by displacement currents but we can measure exactly the field of the interrupted conduction currents. Even if the details are not so obvious and require a skill to understand but what the equations imply is that the electric and magnetic fields depend only on the source charges. It is our orientation relative to the source charges and their motions that give rise to the details of the fields we measure.
From Maxwell basic equations the only sensible is the existence of ε0 and µ0
∂E/∂x=-Z0 ϵ0  ∂E/∂t
∂H/∂x=-μ0/Z0 ∂H/∂t
And they express that the E field causes the E Filed and The H field causes the H field
WAW what a discovery!!!!
The Equations only express that E and H fields are co-existent, co-substantial, and co-eternal like any two perpendicular sides of a brick neither the length affects the width or the other way around.
Hope it helps
jj
Dave45
We have been looking at the coil, maybe we to start designing capacitors.
Dave45
So what are you asking? Does a cap ha e a magnetic field? No it creates an electric field.
Does dielectric current create a magnetic field in a wire,yes an L c circuit shows this, the coil produces a magnetic field
Reiyuki
Quote from: Dave45 on May 25, 2016, 09:04:39 PM
So what are you asking? Does a cap have a magnetic field? No it creates an electric field.
  When we charge or discharge a cap, in (see pic), a change takes place in the dielectric.  We know energy moves across (series resonance), but I cannot find much information on the actual properties of the 'current' that facilitates this.  Most importantly:  how fast is the propagation between plates?  Does it have magnetic properties, like magnetic flux?  And what are the losses if not inductive?
  When it is static (not being charged/discharged), there is no energy transfer in the dielectric, so it is a 'neutral' condition.
@myenergetic,  I think I understand what you're saying, but I'm not sure how to apply any of it.
Quote from: Dave45 on May 25, 2016, 08:56:27 PM
http://www.ourenergypolicy.org/wp-content/uploads/2012/05/130-Electrical-Energy-Innovations.pdf
Page 9 Induction Coil Coating Increases Generator OUTPUT by 1/3
Are you using it,Dave 45 ? Could you give me the "know-how" ? ;)
http://worldwide.espacenet.com/publicationDetails/originalDocument?FT=D&date=20080812&DB=EPODOC&locale=en_EP&CC=US&NR=7411363B2&KC=B2&ND=4
Conservation of Electrical Energy and Electro-Magnetic Power in Motor, Generator, and Product Components
Double Wire Winding In the preferred embodiment, double wire winding is used for the inductive winding. In the conventional art, wiring is done in opposite directions. The present disclosure conserves energy by wiring in a common direction. FIG. 14 and FIG. 15 illustrate double wire winding. The figures show how two wires are wrapped around the core in the same direction. As soon as the end of the core is reached, the wires are brought straight back to the starting position and wrapped in the same direction again. The wiring is done in multiple layers.[/size]The two wires used to create a double wire winding are labeled Wire A and Wire B with the associated - or + sign to indicate the direction of current flow. In the figures to follow, the labels "A+, A-, B+, and B-" will be used to illustrate how the double wire winding is connected to the incoming power line and the capacitor. The negative (-) end of Wire B (B-) should be connected to the first incoming power line node and the negative (-) end of Wire A (A-) should be connected to the second incoming power line node. The positive (+) ends of Wire A (A+) and Wire B (B+) should be connected to the capacitor.[/size]
and/or
http://www.arestov.de/index.php/de/elektromotoren/windenergie
Beispiel: Eine Windkraftanlage mit Nominial 400 W (Herstellerangabe) erzeugte bei einer Windstärke von ca. 20 m/Sek. eine Leistung von 70 Watt. Nach Umrüstung des Generators auf kombinierte Wicklungen lieferte die Anlage bereits bei einer Windstärke von 5-6 m/Sek. 140 Watt. Bei 10-12 m/Sek. wurden über 320 Watt erzeugt!
translated :
Example: A wind turbine with Nominial 400 W (manufacturer information) generated at a wind speed of 20 m / sec. a power of 70 watts. After conversion of the generator windings combined the plant has already supplied at a wind speed of 5-6 m / sec. 140 watts. At 10-12 m / sec. about 320 watts were produced!
        Coating these coils ?!
and for the drive side:
http://worldwide.espacenet.com/publicationDetails/description?CC=MY&NR=137586A&KC=A&FT=D&ND=3&date=20090227&DB=EPODOC&locale=en_EP
In FIG. 4, showing a three-phase implementation of the invention for a three-phase motor 410 (which may be substituted for the motor 260 in FIG. 2A), the input wire for phase A is attached to the left terminal of a first capacitor C1, and another connection is made from a right terminal of capacitor C1 to a left terminal of capacitor C2. The input wire for phase B is attached to the left terminal of capacitor C2, and the other terminal of capacitor C2 is connected to a left terminal of capacitor C3. The input wire of phase C is attached to the left terminal of capacitor C3, and the other terminal of capacitor C3 is connected to the left terminal of capacitor C1. [/font][/size]An output wire for phase A is connected from the left terminal of capacitor C1 to the phase A input of the motor. The output wire for phase B is connected from the left terminal of capacitor C2 to the phase B input of the motor. The output wire for phase C is connected from the left terminal of capacitor C3 to the phase C input of the motor. Test results using a motor configured as in FIG. 4 are as follows: TABLE 6Readings  Readings  Workat 410  at 410  PerformanceBaseline  Three Phase  20.5 psi  Implementation462  V  462  V  1.7  A  1.6  A552  W RMS @  185  W RMS @  20.5 psi  watt meter    watt meter552  W per hour  185  W per hour
More info about motor and generator construction and performance improvements:
William Putt
http://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=william+putt&IN=&CPC=&IC=&Submit=Search
Fred Miekka
http://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=fred+miekka&IN=&CPC=&IC=&Submit=Search
Sankar Pat ,Ronbach array
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20130314&CC=US&NR=2013062983A1&KC=A1
applied:
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=20111006&CC=US&NR=2011241349A1&KC=A1
[0040] As illustrated in Table I (above), the Ronbach magnetic array of both the [/font][/size]electromagnetic generator/motor 1 (FIG. 1) and the electromagnetic generator/motor 1a (FIG. 1A) improve the output of EMF 8 and torque significantly over conventional single-magnet arrays. [/font][/size][0041] Referring next to FIGS. 3A-3D of the drawings, an exemplary design of a three-phase electromagnetic generator/motor which has a Ronbach magnet array and is suitable for implementation of an illustrative embodiment of the windmill generator is generally indicated by reference numeral 10 in FIG. 3C. The Ronbach magnet array of the electromagnetic generator/motor 10 may be compatible with the design of both AC motors and DC motors.
[/size]
Charles Flynn
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=102&ND=3&adjacent=true&locale=en_EP&FT=D&date=19930805&CC=WO&NR=9315513A1&KC=A1
If the coil is energized in a manner such that the magnetic field of the coil opposes the field of the permanent magnet on which it is mounted, then the north pole of the permanent magnet will short to the south pole of the coil and the south pole of the permanent 5 magnet short to the north pole of the coil. In other words the coil will produce a counter magnetomotive force that opposes, and therefore cancels all or a predetermined portion of the magnetic force surrounding the permanent magnet. If the opposing magnetic field of the coil equals or nearly equals the field surrounding the permanent magnet, the effect is to neutralize or make the effective field of the permanent magnet equal to zero. If it has been reduced to zero in the manner indicted then even if another permanent magnet if brought into close proximity to that magnet it will not be attracted or be magnetically coupled to the permanent magnet whose field has been cancelled and in effect the magnets will be isolated from each other. This happens in much the same way as putting an iron keeper on a horseshoe magnet. Cancelling the field of a permanent magnet has the further effect of blocking outside magnetic fields from reaching or coupling to the permanent magnet whose fields has been cancelled in this way. Therefore, not only does the coil cancel the effect of the permanent magnet but it also blocks or prevents other magnets including other permanent magnets brought into the vacinity thereof from having their fields reach the field of the magnet whose field has been cancelled. In other words the magnet whose field is cancelled is magnetically isolated from other magnets. It is this phenomenon of the present invention that enables interrupting the coupling between the magnets including between a stationary magnet and a rotating magnet, and this condition exists even when relatively large and powerful magnets are used. This also enables a relatively small device to be able to produce substantial rotational force and torque.
If the coil on the permanent magnet is oriented so that when energized the field of the coil is in aiding relation to the field of the permanent magnet, the resultant magnetic force will be increased to at or near the combined fields of the permanent magnet plus the field due to the energized coil. Under these circumstances the permanent magnet will attract (or repel) a second permanent magnet brought into the field thereof such as a rotating magnetic member, and will produce even greater coupling force between the members and at even greater distances between the magnets. This fact can be made use of in the present device to increase the torque generated in some embodiments.
