Gravity assisted power project- GRAM
Started by burnit0017, June 11, 2016, 05:07:37 AM
burnit0017
https://youtu.be/THHGEgtjDFs
abandoned TSO for a pulse motor to drive the Swing5, will use stepdown gear train for increased torque
burnit0017
https://youtu.be/8OISfRpDZSE
requires a better design of the electromagnet, suggestion welcome
burnit0017
antijon
Hey burnit, just curious but do you have a way to adjust the timing of the pulse? Looks like if you're in attraction mode you could pulse a little before the magnets are lined up, and maybe have better rpm. Reminds me of when I took the flywheel off a mower engine then tried to start it. The timing was so close the piston bucked back instead of crossing TDC, nearly pulling my arm off before the starter rope popped.
Anyway, timing is important in any machine.  ;D
