24/365 solar cell output theory and experiments
Started by lancaIV, June 23, 2016, 07:30:16 AM
Dave45
Electrons=ions
You guys know this is what kapandze is doing,  ;)
A coils magnetic field is opposite polarity of the applied current.
This is why a coil pulsed with dc will give ac.
Pulse a coil with a pos pulse an get neg bemf, pulse a coil with a neg pulse an get a pos bemf.
Ionized air, oxygen an nitrogen
tak22
So many different types of solar cells to select from! I expect the ideal would be one that allows for the through transmission of light for photons to interact with multiple cells in the stack, and a type that allows for magnetic connection both sides. Any suggestions for what to purchase for experimenting/replicating is appreciated.
http://www.google.com/patents/US20060121748
The coupling device according to the invention is elucidated on the basis of an exemplary embodiment, Wherein thin-film solar cells With a titanium carrier foil are coupled.  It is pointed out that within the scope of the inventive concept the coupling device is equally applicable for coupling thin-film solar cells with a metalized plastic carrier foil.
It is emphasized that in the context of the present invention "thin-film photovoltaic cells" include all photovoltaic cells Which have a thickness such that they are suitable for electrical coupling to a coupling device according to the invention. Examples of such photovoltaic cells are chalcogenide cells, in particular copper indium(gallium)selenide (Cl(G)S) cells, cells With amorphous silicon, organic cells and dye-sensitized liquid cells.
tak
http://web.archive.org/web/20070602085657/http://www.io.com/~frg/
Like the TAC generator in the video, this tiny MEMS thermoacoustic generator  converts heat into electricity.The source of heat can be solar radiation,[size=-1] waste heat from combustion, even body heat. It requires no maintenance and is cost competitive with all existing power generation equipment.
Cost of capitalized equipment:                                     MEMS-TAR < $0.10/W
  The MEMS-TAR is an innovative micro-miniature generator-on-a-chip that uses sonic energy to convert heat into electricity.  It integrates signal processing, power conditioning and control circuitry all in the same package, and can be configured as an eight pin DIP chip.  It can be used singly or packaged into panel arrays for harvesting solar energy at five percent of the cost of competing technologies such as photovoltaics.
http://web.archive.org/web/20070804183450/http://www.io.com/~frg/tar.htm
The MEMS-TAR handles more throughput and has a greater output than PVs. It can produce two or three times the output, for a given surface area, [/font][/size]as conventional photovoltaics--~600 Watt/sq. meter for MEMS-TARs
vs. ~200 Watts/sq. meter for PVs.
With water cooling the MEMS-TAR can easily tolerate throughputs of >10 Watts/cm2.
It can withstand stagnation temperatures in excess of 600 F (315 C) for long periods without damage.[/font][/size]
10  Watts/cm2 = 100 000 Watts/sqm : how much the costs per Wp including the cooling system costs ? (cooling: IBM solution ?)
http://www.google.com/patents/US5009243 concentrator,evacuated chamber,magnets,special gases + TAR cell array
ramset
Lanca
you found the patent info !
Thank you
I will call the TAR link and report any result.[they are a few yours behind me , still early there
Chet K
Thanks Grandma
ramset
Lanca
Nobody picking up the phone at those contact numbers for Thermo acoustic cycle generators  or TAC  .
Thanks Grandma
