24/365 solar cell output theory and experiments
Started by lancaIV, June 23, 2016, 07:30:16 AM
Autsch ! Chet,you are right ! ::)  Mr.Salvodor got me ! >:(  ( Savethesmell)
100%,neither as tandem nor triple-junction cell, in efficiency was really surprising ,Carnot limit ! 8)
I know now the fundamentals :-\ ;D
solar cell concepts but as artificial light source solution:
http://www.greenbusinesslight.com/resources/lighting-lux-lumens-watts
a measurement of 1 lux is equal to the illumination of a surface one metre away from a single candle.
Lux : definition by 1 mtr. distance ,1/10 -1/100 distance effect ? linear/progressive?
         lux/lumen relationship
Bernd Koehler
1 mtr fluorescent lamp : solar cell arrangement ? sqcm aerea? market product efficiency 1985 ?
old 35 W lamps are today newer 20 W lamps light-emitting equivalent
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3817730&OPS=ops.epo.org/3.1&SRCLANG=de&TRGLANG=en
Hans-Dieter Goeres
human syntax error ? : lamp description 6000 K are not 6000 candela but 6000 Kelvin !
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=12&ND=3&adjacent=true&locale=en_EP&FT=D&date=20120322&CC=DE&NR=102010035706A1&KC=A1
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=102010035706&OPS=ops.epo.org/3.1&SRCLANG=de&TRGLANG=en
https://www.google.pt/search?q=solar+cell+mirror&client=opera&hs=yFI&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwituf7ZjP3OAhWHAcAKHawLDBgQsAQIIQ&biw=1024&bih=637
Paul Heinrich Marzahn ~ Koehler + Mirror: light intensity amplication
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=heinrich+marzahn&IN=&CPC=&IC=&Submit=Search
solar cell output enhancer:
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=U1&LOCALE=en_EP&NUMBER=29520064&OPS=ops.epo.org/3.1&SRCLANG=de&TRGLANG=en
lamp consume saver:
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=U1&LOCALE=en_EP&NUMBER=29703156&OPS=ops.epo.org/3.1&SRCLANG=de&TRGLANG=en
It has been found that the power consumption of a Ökolampe(=CFL) without the inventive device to 24 W is approximately 23, while falls within the inventive device the consumption to 1 W or less.
Baquero Menendez ~ Paul Marzahn configuration x 3
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20100615&CC=ES&NR=2341161A1&KC=A1
http://inhabitat.com/u-s-army-patents-new-solar-cells-that-are-1000-times-thinner-than-current-technology/
solid panel to thin film foil to liquid paintable layer
https://www.linkedin.com/pulse/20140715210742-119287260-the-science-of-solar-power-solar-liquid-power-slp-as-a-coating-or-paint
http://pv.energytrend.com/knowledge/Cells_Solar_20121113.html
total EM-bandgap to IR-nm concentrator and IR-2-electric converter
and refraction methods using
http://www.osmatech.net/page3.html
We noticed, when we use our combo 3 on multiple layers of glass, heat increases with each layer. So there is no limit to how many times we can increase heat. Combo 3 increases heat which is a light and color (infrared), but slows down the speed and lumens of the light. (This is not important, because light is very fast and we need the heat not the light.)
Probably in future possible with translucent graphene.( nano-diamonds array)
http://rexresearch.com/zaymidor/zajmidor.htm
http://www.photonics.com/Article.aspx?AID=48486
"When we illuminated the BFO thin films, we got very large voltages, many times the bandgap voltage of the material itself," said Ager. "The incoming photons free electrons and create corresponding holes, and a current begins to flow perpendicular to the domain walls — even though there's no junction, as there would be in a solar cell with negatively and positively doped semiconductors."
http://www.google.com/patents/US5009243 the magnet effect
finally to this "thin film resonator" http://www.greenoptimistic.com/green-ferrite-solar-cell-japan-20110920/#.V8_751pX9aY
CFL for the CFC : compact fluorescent lamp for the cold fusion chamber :
http://atom-ecology.russgeorge.net/2014/12/04/compact-fluorescent-fusion/
http://www.edisontechcenter.org/Fluorescent.html
telecom
The particles in the Russian patent are made from radioactive material, which convert cosmic rays into the
gamma, which in turn can be converted into the light by well - known fluorecent materials, like zinc sulfate,
which then can be used by the solar cells.
https://en.wikipedia.org/wiki/Cosmic_ray
does it need a betavoltaic conversion ?
no radio-active material as cell material disclosed !
https://patentscope.wipo.int/search/en/detail.jsf;jsessionid=62C7E4D7DC7396721B13F05A7FD9C1AF.wapp2nB?docId=WO2005019324&recNum=1&maxRec=&office=&prevFilter=&sortOption=&queryString=&tab=PCTDescription
more related to:
Planksche Nullpunkt-"Zeropoint" Energie : particle mass / particle hole mass
                                                               eV(dyn/erg) min/ eV(dyn/erg) max
telecom
This is what it says:
"said particles being of a metal material which is different than a material of the carrier"
I'm sure that its a radioactive material because its the only material which can capture the so called "cosmic rays"
