24/365 solar cell output theory and experiments
Started by lancaIV, June 23, 2016, 07:30:16 AM
1500 Wh per day and 390 Wp appliances use limiting means  5000 Wh battery capacitance in Ah.
"artificial solar cell system" 2 stages : reduce the capacitance/charge need to 200 Wh per day
                                            3 stages: reduce the capacitance/charge need to    20 Wh per day
                                            partial 3rd stage output back to recharge the battery
                                                             2nd search :
the permanent or part-time working fridge/freezer and the heating/cooling and the fresh water delivery
fresh water: no-/electrical ? with/out grey-2-white-water-recycling ?
freezer/fridge: Kenmore 30W permanent  or mtbest.org 100Wh per day  ?
cooling : (low)heat2electricity-converter ? or simple solar cooling
heating: resonance heating( as FIR/NIR heat wave source)
Quote from: lancaIV on September 09, 2016, 06:07:37 PM
Battery as energy storage:
iron                       http://www.essinc.com
saltwater               http://aquionenergy.com
sodium/natrium    https://www.youtube.com/watch?v=bKpM325YipQ
aluminium             http://www.nature.com/nature/journal/v520/n7547/full/nature14340.html
                             http://news.stanford.edu/2015/04/06/aluminum-ion-battery-033115/
carbon/graphit/nano-carbon ?
hydro-carbon ?
phyto-carbon ?
From the thread : very efficient wind generator design
"artificial-solar" cell light system can work 24/365 or periodically , an advantage
wind generator ? concentrated wind power periodically work up to 24/365 work
a.conventional wind turbine                                                    natural wind current dependant
+ combined coils generator
b.waters-turbine        naturall wind current dependant
c. https://www.google.com/patents/US8283799           natural warm air and wind current dependant
+ combined coil generator
https://www.patentauction.com/patent.php?nb=9374
his local -Arizona,hot air climate/thermosyphon stream/current- measurement data:
up to 80 US$ per month /3 ~ 27 US$ per 400W turbine system and month ,
how much get/reduce their bill in Arizona the consumer/private household producer for feeding the grid ,ea. KWh  ? KWh daily peak and average,monthly peak and average
https://www.dasolar.com/home-wind-power/arizona   Answer ?
d. ambiental dense air mover,concentrator and accelerator    natural climate and humidity dependant
    = motor and fan in a tube/channel
Quote from: lancaIV on September 07, 2016, 11:01:38 AM
L.I.S.A developed by BAYER as Makrolon(TM) during the 80`.
http://factor-tech.com/green-energy/7287-transparent-solar-collector-to-turn-skyscrapers-into-power-plants/
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20100615&CC=ES&NR=2341161A1&KC=A1
instead 8 solar panels 8 L.I.S.A. panels and only the thin side equipped with cells ?
https://www.researchgate.net/figure/49586420_fig1_Figure-1-Luminescent-solar-concentrator
Not all 4 L.I.S.A. panel thin sides equipped wth thin cells caused 3,2,1 sides are painted with reflective paint ? http://ars.els-cdn.com/content/image/1-s2.0-S0022231312000907-gr1.jpg
the artificial light source:
http://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=4349768A&KC=A&FT=D&ND=5&date=19820914&DB=EPODOC&locale=en_EP
Life testing of circuits in accordance with the invention has shown the operating life of both lamps and starters to be 70,000 starts, equivalent to 190 years of daily use, more than ten times the rated life of the starters and more than twenty times the rated life of the lamps when used with prior art ballasts.
LISA
old idea,publicated in the 80` but not forgotten
https://books.google.pt/books?id=96DnlrVhzDsC&pg=PA100&lpg=PA100&dq=popular+science+light+funnel&source=bl&ots=CNbQ5mEYQk&sig=5N13gPyT25HCIph-A5njq3sYO3I&hl=de&sa=X&ved=0ahUKEwjBjbSz-IfPAhXEKsAKHQh4An8Q6AEIKzAE#v=onepage&q=popular%20science%20light%20funnel&f=false
http://www.dailymail.co.uk/sciencetech/article-2733936/Could-turn-windows-solar-panels-Transparent-material-harvest-energy-make-buildings-efficient.html
The glowing infrared light is guided to the edge of the plastic where it is converted to electricity by thin strips of photovoltaic solar cells.
