regenerative acceleration
Started by life is illusion, July 01, 2016, 07:31:51 PM
gotoluc
Before you do the reverse test of removing one bolt generator coil at a time as I suggested above, make sure to also take note of your battery Voltage (with motor turning) with all three coils in place and take note of the voltage as you remove each bolt gen coil.
Now you should have three Volts and Amp sample of each scenario and be able to calculate the input power (in watts) of how much each bolt gen coil loads down the input.
Next, take your amp meter and select AC Amp setting and connect it across one of the wires of your last gen coil while under load and also measure the voltage across the load with the meter on AC volts.
Now multiply your input battery voltage with the Amps (average if you wish) you measured when removing each bolt coil.
(example) input battery voltage was 12.32vdc x 0.42 amps = 5.3 Watts
Then do the same with what you measured on the load (example)  6.5vac x 0.32 ac amps = 2 Watts
By doing this math and comparing Watts In with Watts Out you will realize the apparent free output even if you add the input watts reduction when gen coil is on load, your Watts out will be less then the cost of Watts in to introduce a bolt core gen coil.
I'm not trying to discourage you but rather help you get to the real results sooner as I have been down that path.
Wishing you all the best with your experiments
Luc
life is illusion
Dear Luc and dear Erfinder,
Thank you for commenting.
As I mentioned in the video, this model was my first prototype and I believe was lucky to be able to observe the acceleration under load thingy in my first try ^_^
This experiment showed me that phase shift is possible and to me this is a very good news :D
Core drag is always present in average generators. But when put on load, their rpm drops and they start consuming more power. I believe AUL systems don't have that problem and I think that's a great news. I will use the results of this test (possibility of phase shift) in future experiments :)
Best Regards
Sam
life is illusion
Oh, I also think only because we are searching for OU, that doesn't mean we should discard more efficient generators. I think Generators which are capable of doing AUL are much more efficient than our average generators :)
gotoluc
Thanks Erfinder for posting your comments and video demo.
Your years of research has evolved to not using any core material, which is what one ultimately want.
Will user life is illusion be able to achieve this leap?
What I was trying to point out is, using a steel bolt as core easily demonstrates the effect but is a loosing battle if you keep building on this direction.
As you point out and I agree, Phase Shift is of importance and I think life is illusion is on to it.
So, what's going on in a steel core when the coil is distanced away from the magnet rotor?
Is there a way to create the same effect using air coils only?... there must be since you demonstrate it!
Could a delay line help?
Many things to think about ;)
Luc
gotoluc
