use pulleys to multiply total # of rotations = AC electricity
Started by that_prophet, July 02, 2016, 11:35:19 AM
vkrmvkrm11
Quote from: that_prophet on May 05, 2017, 05:52:24 PM
Free energy is as simple as the pre-school technology of using pulleys to multiply rotations
+ multiplying AC electricity with multiples of both size and #'s of pulleys
= https://free-energy.yolasite.com/
- this is so super simple,
that we should be ashamed of allowing satan
+ his fellow evil spirits, to have kept it hidden
for so long = ever since Ezekiel 1:16
- "a wheel in the middle of a wheel",
where it was the first simplistic described how a UFO motor worked in the Holy Bible,.
You only pay one small bit of DC current
to rotate 100 cm circumference pulley one single time,,,,
+ through running the 100 cm of moving belt,
(which came off the circumference of pulley)
+ running it by 10 of the mini- 1cm circumference pulleys
+ attaching AC generators to each pulley,
you can multiply your AC electricity to 10X100=1000 cycles of AC electricity
,,,,,,,,,,,,,,,,,,,,,,,, all for the cost of one spark of DC current
=(just enough to rotate your DC motor one single time)  .  .  .   .  .  .  .  .  .  .  .  .  .  .  .  .  .  .   .  .  .  .
<<< NOW TRY + TELL ME THAT YOU CANNOT GET ENOUGH VOLTAGE FROM THESE 1000 CYCLES OF AC ELECTRICITY,,, + ONLY THE ONE SPARK OF CURRENT, THAT IT TAKES TO ROTATE YOUR DC MOTOR ONE SINGLE TIME >>>
(I hope this makes you realize reality, + how powerful spiritual warfare is going on all around you every day)
YES,,, GOD IS REALITY,,, + HE IS COMING BACK BEFORE 2019.04=Door –(in air for all born-again who are looking for His Coming)
although we are warned that "of that day and hour knoweth no man"-Mat 24:36,
we are also told that we can "know that it is near, even at the doors"-Mat 24:33
Just think of it this way, you are only putting in one small bit of DC current,
Enough to crank over your DC motor once, with a 100 cm circumference pulley attached,
+ through simple pre-school  pulley mechanics, of running this 100 cm of moving belt,
that comes off the one rotation of your 100 cm circumference pulley,
Past 10 mini-pulleys of 1 cm circumference, with free running AC motors/generators attached,
+ you will get 10 X 100 = 1000 cycles of AC electricity.
All for the cost of DC current to rotate your DC motor one single time = only one spark
http://decimationofthisevolutionfairytale.yolasite.com/
http://free-energy.yolasite.com/
http://my2020vision.yolasite.com/
http://doorschristmustpassthrough.yolasite.com/
http://beliefstoliveby.yolasite.com/
http://fire-starter.yolasite.com/
http://2020vision.yolasite.com/
http://one-christian-warrior.yolasite.com/
good
AlienGrey
that_prophet
EVil-sOLUTION - free energy can be found in a UFO motor description in Ezekiel 1:16
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year peace treaty with Israel MUST START before the Door closes on 2019.04-"know that it is near, even at the doors" Mat 24:33   http://doorschristmustpassthrough.yolasite.com/ . DOOR = (Christ must return before date) We were given the best Gift from God, (other than Jesus) right here in Atlantic Canada + just before the infamous 7 years Peace Treaty, + 2nd half as being the (Great Tribulation) where most all of the fallen angels, and Nephilum = angel offspring with women will be sent to the earth. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood.
What is AC electricity, + how is it made, out of rotations of a coil of wire through a magnetic field right, + a set of varying sized pulleys, can be easily used to multiply the total # of rotations. This is one free energy technology that we all will need and love = no cost, fuel or exhaust. So,,, why haven't we figured this simple little bit of technology. Can you believe the power of evil spirits, to be able to dumb down a whole population of humans. Think this may be a reason to find God http://beliefstoliveby.yolasite.com/
Do you want to hear how super simple this technology is,
Where you only pay to crank over one time, the DC motor + one 100 cm circumference pulley,
Then you use the 100 cm of moving belt off this large pulley circumference ,
+  run it past 10 mini-pulleys of only one centimeter circumferences,
All that you have to do is add AC generators to these 10 mini-pulleys,
Giving you a free return of 10X100=1000 cycles of AC electricity.
That's one small pulse of DC current as an input, returning you 1000 cycles of AC electricity,
You are using the dirt simple laws of pulley mechanics to multiply rotations,
+ since AC electricity is generated by simple rotations
Believe it or not, you are using this pulley mechanics, to freely multiply your AC electricity
+ you could easily multiply your AC cycles of electricity
IT IS TRULLY THAT SIMPLE..................................
You are using simple Pulley mechanics to multiply AC electricity cycles
And don't you believe that torque is a problem,
You have 10 X 100 = 1000 cycles of AC electricity,
To make up the one spark of DC current that you need,
That this DC drive motor needs to be cranked over the one time,
Giving you the 100 cm of moving belt = off 100 cm circumference,
This motor – generator power system is self powering,
It can do this by creating massively more electrical power from your many # of AC cycles,
That you can produce from your many AC generators, attached to many of these mini-pulleys,
Which are so easy to rotate, because it does not take 100 times more power to rotate a large pulley,
Yet this large pulley gives you 100 cm of moving belt off one single rotation,
Which by passing by 10 mini-pulleys with AC generators, can produce 10X100=1000 cycles of AC electricity, thereby multiplying your total amount of cycles of AC electricity,
By only needing a miniscule amount of DC current to rotate only once,
+ producing as many thousands of cycles of AC electricity, as you added the # of mini-pulleys,
With AC generators attached
CAN YOU BELIEVE HOW SIMPLE THIS TRULY IS
+ how powerful this spiritual warfare must be,
to be able to hide this super simple AC multiplier from us gullible humans..............
We can use pulley mechanics to freely multiply rotations,
Thereby we are using pulley mechanics to multiply cycles of AC electricity
I don't know about you, but I was amazed at how simple this preschool way of using pulleys to multiply your # of rotations, thereby multiplying AC electricity by using this simple pulley technology. And can you believe the power of evil forces, to be able to hide this super simple way of using pulleys to multiply the total # of rotations, or AC electricity. For how long,,,,,,,,,,,,,,,,,,,,
Think about this, for how long have they been able to hide this free AC multiplying technology,,,,
The thing is, that there is the most powerful spiritual warfare going on about this simple free energy technology, and evil forces will immediately start confronting you as soon as you start looking into this. I can be sure that evil forces will whisper in your ear, many ways that this cannot possibly work. For why should evil spirits want us to be able to stop buying oil, from nations that in one way or another tend to promote terrorist, and their careless destructive ways. I believe that God gave me this technology back in the early 2000's when He first gave me a Vision of a 10 speed bicycle going uphill in 10th gear, and then back downhill in 1st. This is very significant where AC electricity is concerned, where you may need massive voltage, to crank over the pedals on the way up, but it costs way less current, as the motor runs for only a few rotation. Then when you run the bicycle down the hill in 1st gear, you would be winding over your AC generators massive amounts of time. Please remember that AC electricity is generate through rotations of a coil of wire through a magnetic field, and the more rotations means more AC electricity.
http://possibletimingfortribulation.yolasite.com/
here is one of the forums that my GEM pulley free energy
http://evotutionfairytale.yolasite.com/
(here is a picture that shows basic idea of this GEM tech)
(but the small pulleys should be much smaller + 1-3 not 4)
Come on Canadians,,,
Come on Nova Scotia,,,
This is where this GEM-(Geometrical Electricity Multiplier) technology of free energy for the End Times was 1st started. Let's get out there and start taking advantage of it, by not only building GEM units to power all of our electric tools, toys + gadgets, but we could be starting companies that have electric appliances, utensils, devices, tools, toys, + gadgets with these GEM perpetual power supplies built into them, (let's start letting electricity generate itself) + on our labels we could even proudly say "FIGHTING TERRORISM + FIGHTING POLLUTION"
COME ON,,, ALL OF YOU BACK YARD MECHANICS,,,
Get some AC + DC motors together of the same voltage, and start building these GEM free energy power supplies,, + not only for 1.5, 3, 6 + 9 volt batteries, but household 120, + 12 volt, for powering these new electric cars. Let's throw the oil companies the bird, + maybe even make money with them, by throwing any excess power from these perpetually running energy generators that we have the time, + small amount of money to purchase parts to build. Think of it as not only keeping money in your pocket, but you are keeping money from the countries that fund terrorist. This is not to mention the experimenting that we could be doing with the anti-gravity + speeds approaching light speed. Now I know that there are many out there like me, that would enjoy knowing how one type of this motor was powering a UFO in the Bible, in Ezekiel 1:16.
Although we are warned "but of that day and hour knoweth no man"(Mat 24:36), we are also assured that we can "know that it is near, even at the doors", (Mat 24:33) Where the door closes on the Prophecy when it can no longer be fulfilled. My name is Joe, and I now live at a nursing home in Nova Scotia, and if you can find me an electronic simulator that I can use, I will show you how this free energy technology can and will work for man, instead of man having to work for energy. In any case, please let me show you how all of the barriers can be overcome, instead of taking Satan's words for it, when he or the billions of evil spirits throw excuses at you, for why this will never work. My email is one_christian_warrior@yahoo.ca
This pulley technology works,,,
Here are a few of ideas that others have,
Knowing or not knowing that it is based on the same GEM technology
but just watch + learn THESE DO INDEED WORK
GEM technology is true free energy, except for that former President,
That switched the patent law to be more accessible to others
+ In theirs it only has one mini-pulley, + not 3 or 10 like in mine
https://www.youtube.com/watch?v=IjN1refTtHg
https://www.youtube.com/watch?v=A1ZGOgcZp_g
https://www.youtube.com/watch?v=RD2GrpBIMXc&t
+ you can be sure that more people will come out with their own GEM tech
mankind will hopefully move quickly with this new found pulley technology
where in no time, people will be starting up factories to add this free energy tech
to all electronics + electric mechanisms + yes, even automobiles,,,,,,,,,,,,,,,,,,
can you imagine cars that don't cost any fuel to travel, any amount of distance you want
+ think of how the cost of everything will go down, with no fuel costs to transport stuff,,,,,,,,
profitis
 But if behind the Father and the Son we
see and taste the power of the Holy Spirit and reject his work
as no more precious than the work of Satan, we shut ourselves
off from the only one who could ever bring us to repentance.
And so we shut ourselves off from forgiveness.
that_prophet
TIME IS SHORT = the Pre-Trib Rapture + the infamous 7 year Peace Treaty with Israel MUST START before this 1ST DOOR closes on 2019.04 = Jan 14th http://my2020vision.yolasite.com/ - "know that it is near, even at the doors",(Mat 24:33) http://doorschristmustpassthrough.yolasite.com/.
Free Energy + perpetual motion can be easily produced using pulleys, costing only the minuscule bit of power that it takes to rotate a DC motor with a large 100 cm circumference pulley one single time. You can gain or multiply massive amounts of AC electricity using mini-pulleys with AC generators. You are capable of doing this by running this long length of belt, (off the circumference of large pulley) past a few 1 cm circumference mini-pulleys, with AC generators attached. This GEM-(Geometrical Electricity Multiplier) device is gaining you 100 cycles of AC electricity, for every mini-pulley that you choose to attach to this sane belt. So, if you added 10 mini-pulleys, you could get a return of 1000=10X100 cycles of AC electricity, and all costing you only one mere spark of DC current. How could you not be multiplying AC electricity, when you are using simple pulley mechanics to trade one spark of DC current, for 100-1000 cycles of AC electricity-(duel sparks).
This super simple free energy technology: http://free-energy.yolasite.com/ works on the ability of combinations of pulleys being able to easily + freely multiply your total # of rotations. You can do this because of the fact that you don't have to expend 100 times more electricity to rotate a large 100 cm circumference pulley, than it takes to rotate a 1 cm circumference mini-pulley. Yet if you run the 100 cm of moving belt, that comes off the one rotation of a large 100 cm pulley, past any # of mini-pulleys of 1 cm, then you could gain a return of 100 rotations for every mini-pulley that you choose to attach to the same belt. (As for torque, it only comes from generating power, and power is voltage multiplied by current) + We only need to produce one single spark of DC current to make this a self-powering mechanism. So one spark of DC current, (which is practically nothing) multiplied by even massive voltage, would still equal practically zero power, which takes practically zero torque to rotate.
This multiplication of rotations could be extremely helpful, if you only added AC generators to these mini-pulleys, you could be multiplying the total cycles of AC electricity. This AC generator takes no torque to rotate, because although it would be winding up massive voltage, it does not need to be winding up practically any current-(1 mere spark) which is practically zero. Torque is only caused when you are generating power, and you are generating practically zero power, as power is equal to voltage times current. So, no matter how massive of voltage you are generating, it is multiplied by practically zero current, as we only need one spark of current, or practically zero. This works because zero times anything is still equal to zero, and practically zero works the same way.
What is AC electricity, + how is it made = it is made out of the easy rotations of coils of wire through a magnetic field of two oppositely positioned magnets right. Using pulley technology, we can easily + freely convert one rotation of a large 100 cm circumference pulley, into 100 rotations of as many 1 cm circumference mini-pulleys that we choose to attach to the same belt that comes off of your large pulley. So, if you added 10 mini-pulleys to this same belt, and added AC generators to each mini-pulley, you could gain you 1000 = 100X10 cycles of AC electricity.
All these cycles of AC electricity are from the single burst of DC electricity, which is the small amount of current that a DC motor takes to rotate one single time =(one mere spark). These cycles of AC electricity would cost practically zero torque to rotate, as torque is only caused when you are generating power, and you are not generating practically any power in this system. This is because although you may be winding up massive voltage,(electrical pressure) to keep this GEM mechanism running, you only need to generate one single spark of DC current, and P=IV, or power equals current multiplied by voltage.
So your total power output would be practically zero current multiplied by any amount of voltage, which would still be equal to practically zero power, taking practically zero torque. So, you could be easily + freely generating massive amounts of rotations of these mini-pulleys, which are generating you massive voltage, or the ability/potential to gain plenty of current, which will allow you to produce plenty of power. This is because the greater the voltage/pressure, the greater the ease that there is to generate more current. PLEASE,,, let me show you how ridiculous this mythical torque problem really is. Do you think that the 100 cycles of AC electricity would have a hard time producing the single spark of DC current, which is all that you need to crank over your DC motor once, with your 100 cm circumference pulley attached?
Mankind was given the best Gift from God, (other than Jesus) http://free-energy.yolasite.com/ right here in Atlantic Canada + just before the infamous 7 years Peace Treaty. This seven years of time, which the 2nd half of is the Great Tribulation, is when this GEM tech will be needed most. This will be the worst time for earth, where not only is there constant war, but most all of the evil fallen angels, and the Nephilum , will be sent to the earth. Nephilum are the offspring of fallen angels + human women, as angels are all male, because God only wanted there to be a set # of angels. This is not only the ones that are still alive, but also the spirits of all that have died. This could be massive amounts of evil spirits, considering that this includes the ones from before the flood. (How can we be billions of years old, when the moon will leave orbit within 10,000 years) + all orbiting bodies will have messed up orbits, because of this yearly amount of space debris adding mass.
This is free energy technology, which we all will need and love, as it has practically no cost to run, and there is no need for any fuel to be purchased. Nor would there be any exhaust to cause environmental or noise pollution. So,,, why haven't we figured this simple little bit of technology out long ago? Evil spirits are, and have been hiding this simple technology from mankind. These AC generators are extremely easy to rotate, because the only resistance torque,(other than the viscosity of the lubricant in the bearings) would come from a great need for current, which would practically never happen, especially when you are dealing with such small amounts of power as the example that I describe here.
I confirmed that this free energy technology, discovered in the early 2000's, was from God + not from evil forces, by finding it in a UFO motor description in Ezekiel 1:16. Thankfully, there are many ways that we can freely multiply the total # of rotations, like a set of varied sized pulleys, can be easily used to multiply the total # of rotations. Then, by simply adding an AC generator to your mini-pulley, you can convert your rotations into cycles of AC electricity.
This is one super simple GEM of an idea, and it is made from pre-school technology, so why was this not out long ago. Can you believe the power that evil spirits have, to be able to dumb down a whole population of humans + for so long. I still have problems getting people to believe that there is no torque problem. Think that this may actually be a good enough reason for you to find out if GOD IS REAL = http://beliefstoliveby.yolasite.com/ + if HE IS RETURNING SOON = http://my2020vision.yolasite.com/
Do you want to hear how truly super simple this technology is, Where you only pay to crank over the DC motor one time, with a 100 cm circumference pulley, Then you use the 100 cm of moving belt off this large pulley circumference, + run it past one or more mini-pulleys of only one centimeter circumferences, All that you have to do is add an AC generator to these mini-pulleys, giving you a free return of 100's of cycles of AC electricity. That's one small pulse of DC current as an input, returning you 100 cycles of AC electricity output, How can you not multiply your AC electricity, with this rotation multiplication technology
This is where this GEM-(Geometrical Electricity Multiplier) technology of free energy for the End Times was 1st started, (early 2000's when He first shared this with me). Let's get out there and start taking advantage of it, by not only building GEM units to power all of our electric tools, toys + gadgets, but we could be starting companies that have electric appliances, utensils, devices, tools, toys, + gadgets with these GEM perpetual power supplies built into them, (let's start letting electricity generate itself) + on our labels we could even proudly say "FIGHTING TERRORISM + FIGHTING POLLUTION"
