Hulda Clarks syncrometer.
Started by antimony, July 20, 2016, 03:28:32 AM
antimony
I am have read Hulda Clarks book "Cure for all cancers" and in it on page 457 she writes about her syncrometer circuit. The pdf can easily be found by a google search.
It seems like a simple device to make, and i think i have all the components too.
Have anyone here any experience with the syncrometer device?
e2matrix
The synchrometer may be simple to build but from what I understand it is very difficult to use and get accurate results.   I've built Clark's Zapper and it is easy to build and use and it works.   I never saw much reason to use the synchrometer.   I see the synchrometer as being almost along the same lines as using a pendulum for getting yes - no answers.
russwr
The Dr Clark Syncrometer is a yes or no answer for testing contamination of samples on test plates. Also used for test contamination of people by minute quantities of substances. Tone frequency heard the same for no, very fast upward RESONANCE result for yes answer. This works as the operator body is part of electrical circuit. Similar to the low cost simple lie detector boxes sold. Accuracy is very high. Various upgrade models came out on the market over time. The book- The Cure For All Cancers has the simple diagram for a low cost home design. Expensive models are available to purchase at the Ca. shop. There are a few You tube videos on the subject. At Dr. Clark's clinic in Mexico years ago, she tested patients for cancer causing agents such as Orthophosotyrasine and isopropal alcohol . See also her book- The Cure For All Diseases, which talks about the therapy Zapper. (The Tens unit is not a therapy unit)
