FE in the news / new FE offer
Started by lancaIV, September 09, 2016, 08:23:04 PM
memoryman
my comment on your video: Do proper calculations and you'll see that there is NO energy gain.
gotoluc
Quote from: memoryman on September 15, 2016, 01:00:39 PM
How do you know!... have you built and tested it to be so?
memoryman
I did the calculations from what you supplied on the video; no need to build something that can't work.
gotoluc
Quote from: memoryman on September 15, 2016, 04:08:32 PM
I would say your're jumping to conclusions a little too fast.
As far as I'm concerned I didn't provide enough test data in the video to come to a conclusion.
You need to consider the RPM gain when the bulb is applied.
I have done more accurate power measurements then you have which considers rpm in each cases.
So sorry to say but your conclusion is not correct.
Sounds like you want this to fail?
It's sad how negative some are here. Seems to be the opposite direction of this forum!
tinman
Quote from: gotoluc on September 15, 2016, 06:42:42 PM
Couldnt agree more Luc
Setup is looking good,and results are as expected when a load is applied to the prime mover.
Brad
