Deep space propulsion tech using spring force and kinetic energy
Started by vikram_gupta11, September 22, 2016, 06:12:53 AM
vikram_gupta11
In this technology there will be no need of carrying any kind of propulsion material or in other words no need of ON BOARD propellant.
This technology will be 100 times faster than Ionic,plasma or any other propulsion tech.In this way this engine will work. This DEEP SPACE ENGINE which can move at the speed of 6,000,000 to 10,000,000 kilometers per hour or more. This will be a radical step for deep space missions. There will be no need of on-board propellant in this technology (Zero Fuel Technology).
This technology is based on the mechanical engineering and will be 100 time faster, lighter weight and lower cost than any other existed deep propulsion technology (plasma ionic, and other).
MECHANISM:There will be two part of this engine.
(1) First part
(2)Second part
The first part will move freely in a cylindrical tube but second part will be stable.
Two motors will be fixed in this engine as per diagram.the (1) motor will work to press the first part towards front side while (2) motor will work to press the second part towards backside.
Two lever system will be attached with each motor.These levers will work to press their side springs when both motors will move.
There will be Pull Back system attached in the first part of this engine.This pull back system will work to get back the first part of this engine on its position with the help of a motor and Electromagnets.
Two magnetic brackets will be attached with first part as per diagram and springs of first part's will be attached with a magnetic system.
This engine will get energy with Solar panels.
HOW THIS ENGINE WILL WORK?
When the both lever system will work to press their side springs then a kinetic force will create on both springs.
when the (1) lever will press the spring of first part then the spring get stretch due to pressure and at a point of pressure this part  will be detached with its side magnets and  will move towards front side due to kinetic force.But in second part of the device when(2) lever will press the spring towards backside then spring will work to push this device towards front side after removing lever pressure.
In this way both parts of this device will help to push forward this device .
The magnetic bracket will work to catch this first part so that this part couldn't move with back force ,otherwise this engine will move towards backside due to  back force.
The pull back system will work to attach this first part  with the help of Electromagnets.The first part will be detached with magnetic brackets when pull back system will work on this part with electromagnets then  the springs of this part will be attached with their side magnets again and pull back system will be detached.
BOTH LEVER WILL WORK AT A SAME TIME WITH EQUAL FORCE IN THIS ENGINE..
.The first part of this device will get back its position again and both part's levers system will be ready to work on their side springs again and again.
vikram_gupta11
I Took a Rubber band and try to stretched it with my hands and it was stretched .Now I took the help of an another person to catch this stretched rubber band in middle with the help of fingers .after that I released the right part of the rubber band but I didn't release the left part of the rubber band .( still in stretched position) only released the right part .when I released the right part of the rubber band then the person felt a propelling force working on pushing his fingers in left direction of stretched rubber band.
suppose a person is standing up on a roller skate applying equal force with both hands to stretch the springs and these springs are attached with this skate . the roller skate is stable but when this person release ONLY the right hand side spring then the roller skate should move or not.REMEMBER PERSON IS RELEASING ONLY RIGHT SIDE SPRING BUT LEFT SIDE SPRING IS STILL IN STRETCHED POSITION
