How do I test for resonance
Started by Tesluh, October 08, 2016, 03:15:19 PM
Tesluh
the second probe you are referring to might be the frequency counter.  I don't understand the use of a frequency counter unless the output on the signal generator isn't easy to determine.  when it's a digital readout I'm pretty sure the frequency from the counter and the frequency out but by the generator are the same.
antimony
Quote from: Tesluh on November 29, 2016, 09:08:30 AM
the "probe" on my function generator has a two pronged lead.  you need the signal generator and an oscilloscope which also has a probe.  I finally was able to get my equipment to determine the resonant frequency of a coil.  I am not sure how exact the frequency i am coming up with is but I get the rising and falling waveform on the scope.  tried three different signal generators (not sure if I was using them correctly) and ended up with this one that has a built in frequency counter.  https://www.amazon.com/gp/product/B0199SVAIY/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I had two probes on my oscilloscope but now i am using only one channel, and the other probe on the FG-100.
Im not sure if i have one in this cheap fg, but my oscilloscope is able to measure the frequency.
I will probably get another one if i am not able to figure oiut how to use this one soon. :)
Tesluh
does your function generator have a lead with two ends?  mine has a jack that you plug into that says output and the cord has two alligator clips.
Tesluh
if your scope can measure the frequency and it changes when you change the function generator frequency you are most of the way there.
antimony
Quote from: Tesluh on December 02, 2016, 08:30:32 AM
I use my oscilloscope probe. It has one ground clip and one hook.
