Thanks to ALL for your help!!
Transverter technology anybody?
Started by antimony, October 17, 2016, 09:41:47 AM
antimony
Quote from: citfta on October 19, 2016, 06:36:11 AM
I don't think you are being a pain.   I think you are just trying to learn.  Unfortunately I don't really know anything about the TV.  I am a little familiar with the rotoverter but never tried to make one.  From the articles you linked to it looks like they are trying to make use of the ferroresonance of the transformer core material.  The Peswiki article is talking about a particular type of transformer used in industry that maintains a fixed output voltage under changing conditions of either load or input voltage.  They can maintain an output voltage of 120 volts under a wide range of load conditions and with an input voltage from 90 to 140 volts or so.  They are a special type of transformer that is also very expensive.  One of those will cost more than a small 3 phase motor.
There is not enough information in the two videos of the guys who made their own transformers to even begin to guess what they are doing.  But it appears they are only using single phase transformers.  I am not sure why you think you need a 3 phase transformer.
From the responses you have gotten on this forum it appears no one else here is familiar with the transverter either.  Maybe someone else will see your posts and add some more information.
Thanks, i always hesitate to post stuff here unless i am stuck in some way. But I appreciate that you have patience with me. :)
Yeah, I figured that it would be like that, and i would have to get a ferroresonance trafo,  but anyways.
Do you think it can be done with a single phase transformer instead of exclusively with 3phase?
citfta
The circuits shown in the Peswiki article are all using single phase transformers.   Also the videos you posted links to are also using single phase transformers.  So my guess is while you could possibly use a 3 phase transformer it is not required for the transverter to work.  The Peswiki article does not give the total information needed I feel to get the device to work.  I think at the minimum you will need a very good scope and some accurate meters.  With those and a lot of experience working with resonant circuits you might get it to work.  Also you might need a good capacitance and inductance meter to match up the parts of the circuit to get it to work properly.  I feel like just putting some parts together is not going to be enough to get this circuit to work.  I have over 50 years experience working in electronics and I would hesitate to build this without some more information on exactly how it should be tuned and operated.
I wish you good luck if you decide to pursue this project.
If I can help anymore just ask and I will try to respond.  However after today I will not have internet access for a few days so my response may be a little slow.
Carroll
antimony
Quote from: citfta on October 19, 2016, 08:54:44 AM
Carroll
I will try to pick this up in the future, but for now this seems like it will cost me too much money that i don't have.  :)
But I I really appreciate your help Carroll.  Thank you very much.  :)
