LCAP (Again) Possible Free Energy. (Voltage Gain Over time)
Started by TheGeneralHackr, October 28, 2016, 11:57:07 PM
itsu
QuoteWith 5 volts it should rise about 2 to 3 times the voltage of the 2.5v in the same amount of time.
I don't know if you have noticed yet but as you increase the voltage the frequency increases, I'm thinking that may be the reason the voltage climbs faster?  (And the added voltage)
Ex- 1.5V 10hz
      3V 13hz
      6V 18hz
(I'm just guessing the 3V and 6V since I don't have a oscope but you get the point)
What's odd about the frequency is if you try and up the frequency while at a specified voltage ex 1.5V 10hz to 1.5V 20Hz the voltage will drop instead of gain.
Hmmmm,  ok,   good to know again, as overnight, the 4x AA rechargeables dropped 2mV, so we are now at 5.092V.
I had it set at 12Hz like when at 2.5V, so i should/could try doubling the frequency to 24Hz or so.
Itsu
TheGeneralHackr
Quote from: itsu on November 01, 2016, 05:52:44 AM
Itsu
If you keep the 1Mohm resistance the same and apply a higher voltage the frequency will increase on its own
itsu
Right,
from 12Hz @ 2.5V to 65Hz @ 5.092V.
I will let it run with this 65Hz @ 5.092V  for now.....
Itsu
itsu
Voltage had dropped till 5.088V (4mV), so i have decreased the frequency till i saw the voltage rise again (battery recovery?).
That was around 17Hz, so i will leave it overnight this way (17Hz @ 5.089V).
There is a very narrow (100ns) pulse ontop of the battery voltage (5.089V) of around 800mV at every 17Hz pulse, which could (re)load the  batteries and thus partially compensate for the losses in the circuit, see screenshot.
Yellow is the battery voltage, blue the collector signal (end of the pulse).
Itsu
itsu
Not looking very promising, this morning the voltage was back to 5.088V.
I will try some other components like a tantalum capacitor to see if things can be turned around (bigger / wider pulse as mentioned above?).
Itsu
