Overunity with one motor and flywheel
Started by Diorthotis, October 29, 2016, 11:10:11 PM
Diorthotis
I first saw this video
https://youtube.com/watch?v=xvhwEDeEp18
So Im going to try it. I made a flywheel from 4 inch foam board circles glued together with elmers glue all. It was origanally going to be a pully, but I have a cd drive motor (the one that spins thi disc). I will start the system using a wall transformer producing 12v @ 1A, or I may use a smaller voltace if necessary. This is to start the flywheel spinning. I have already done this, and it gets going very fast. I am going to connect an electrolytic capacitor in parallel with the motor, this will be charged by the flywheel as the voltage begins to drop. In this video, it is seen this machine is running continuosly. The single motor produces reverse EMF, which are used to charge capacitors. I will finish my machine when I buy solder and a board to solder components onto from radioshak.
